What do you use your 4 Aux buttons for???
runningonemptyy
roland
florida
2021 wrangler
1 - front pods
2 - raptor lights
3 - rear pods
4 - currently open
Grayhound
Michigan
Jlurd
1) ditch light
2) air compressor
3) aux high beam lights
4) winch cut off
Adv_aw8s
Rob
2021 Rubicon diesel
#3 Rear chase light
#4 bumper reverse/camp light.
I'll use the others for some lp4's or lp6's for the front bumper.
Jeep Wrangler JL What do you use your 4 Aux buttons for??? PXL_20230304_012253818
Jeep Wrangler JL What do you use your 4 Aux buttons for??? PXL_20230304_012224099
Jeep Wrangler JL What do you use your 4 Aux buttons for??? PXL_20230304_012132706
Covet
Los Alamos, NM
18 JLUR, 22 392, 22 4xe JLUR sold x3, 24 392
On my previous Wrangler, spots, floods, winch, and 1 tied to nothing. Current Wrangler, have not added things that need switches yet. Would probably do the lights and winch again.
zouch
Berkeley, CA
XJ, JLUWD
2- snow lights (big yellow H3 Halogens on the front bumper.)
3- ditch lights (LEDs on A-pillar mounts.)
4- front E-locker
JL MADDOG
Michael
Apache Junction, AZ
2021 JL 2.0L Turbo
Jeepin'
1 - Front hitch bumper light bar
2 - Roof rack front light bar
3 - Roof rack rear light bar
4 - (saved for ditch light install)
Spank
I use mine for auxiliary lights, but I also took advantage of the added hot/ignition-only interior wires you get with the switch bank, so I've got my dashcam, CB, and GMRS radios all wired to those.
Opus
Midwest US
www.jlwranglerforums.com
2023 Sport S, 2021 Compass
I've got a set of lights and A-pillar brackets coming soon so that will be my first time wiring to the AUX switches. I'm trying to decide whether I want to wire them both to switch #4 or wire one light to #3 and the other to #4...
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
I'm currently only using one of the lower Amp switches for a winch power interrupt solenoid. I'm contemplating hooking up my gmrs radio to one and the charger for 2 handhelds on another. The last one will eventually be for a cooler.
Forward lighting, aux reverse lights, and rock lights are all on a seperate switch panel on the drivers grab rail. It makes lighting easier to control on the fly, having those buttons up closer to the steering wheel and my line of sight on the roads/trails.
whenasked
Cincinnati
2021 Jeep Wrangler Rubicon Unlimited 4XE
My aux switches turn off by themselves sometimes. Have checked all settings to prevent it. Is this a possible defect?
Omen
Wisconsin
2022 JL Willys 2.0
IT Manager
I crimped/soldered on 2 circuit weatherpacks to each underhood connection. The extra circuit on each is a matched wire gauge ground to the appropriate lugs. I also made blank connectors to cap off the unused circuits to keep them sealed. This allows any accessory to be quickly added (or just tested) with a nice modular interconnect.
1 - 6 way LED lights (latched on ignition)
2 - N.C.
3 - control for the 6 options of the lights on 1 (momentary on ignition)
4 - N.C.
I'm not sure where the rest will end up, and I also added a modified Lasfit Rubi style locker/aux switch system. The modification was to remove the branch that fed into the interior. What is in the cabin from the factory is enough for me.
Omen
Jeepiner
Jeepineer
Toledo, OH
2022 JLURD
Mechanical Engineer
