What do you guys think of these 9” Kiwi Master LED headlights
cbrenthus
FL
'19 Mojito JLUR
It's a start, but I'm not digging the cross shaped halo. Reminds me of the Renegade's tail lights. But I'm excited to see true 9" projectors rather than 7" ones with brackets :)
To a large degree, I think you get what you pay for.
Since accurate and adequate lighting of the road is what the purpose of this modification is all about, I'd look for those attributes in information about whatever choice you make. The Retrofit Shop has a video on their Sealed 7 V2Super 7 (LED projector), and the JW Speaker 8700 Evo 2 dual burn. Their Sealed 7 V2 is by far the brightest and has excellent light placement/control, even better than the JW Speaker from what I saw. But I have read some guys on this forum were having issues with the wiring/connector stuff. Lights have to be reliable first, then reliable second, and reliable third. I'm not going thru the unreliability trade-off for more light I went thru on my truck with aftermarket harnesses, etc..
As for "true 9 inch" lights, measure the front of your grill opening for the headlight. It ain't 9". More light 7 1/8". To some guys it's all about what the looks of the installation are. I can't help with that.
mwilk012
2018 Ocean Blue JLU Rubicon
Service
Don't buy cheap ebay lights for a beautiful new JLU.
Save your money for Quake or Oracle lights. They cost more but will look way better and last much longer.
7” JK lights retrofit onto a bracket to stuff into the JL isn’t exactly what I would consider great.
Arterius2
Arterius2
Jerry
Vancouver, BC
2018 JLU Sahara 2.0L
I bought the said headlights above from eBay, possibly the first true 9" aftermarket LED headlights for the JL, will be arriving in a few days, going to get them installed and update back on the results! Stay tuned!
Spec looks good, High+Low beam feature, and claimed "plug-and-play DRL", we shall see..
mwilk012
Service
Remember to take before and after pictures of the beam pattern and brightness on a flat surface! Reviews on these would be great.
Arterius2
Arterius2
Jerry
Vancouver, BC
So far so good, absolutely love these headlights, they look awesome in person and most importantly they aim low from the factory, no adjustments needed, sharp cut off! I’m going to paint the grille inserts as well in one go, writing up a detailed review, expect something soon!
Jeep Wrangler JL What do you guys think of these 9” Kiwi Master LED headlights 67F0E7ED-3A58-4ED4-BD91-24A6ECF08C3E
Jeep Wrangler JL What do you guys think of these 9” Kiwi Master LED headlights BCB6B7C7-D088-43B4-A70F-4AF7DB422813
Jeep Wrangler JL What do you guys think of these 9” Kiwi Master LED headlights F90F92D7-CE17-4318-9B35-96926BA5900D
Jeep Wrangler JL What do you guys think of these 9” Kiwi Master LED headlights 30913B87-EC0D-4ED3-9502-BD308BB8678A
Jeep Wrangler JL What do you guys think of these 9” Kiwi Master LED headlights 1A3ACD8B-DB4B-4C29-96C1-625A9AC59648
Jeep Wrangler JL What do you guys think of these 9” Kiwi Master LED headlights A0F6F120-EDA7-45FF-AC74-E5C2961537B5
Jeep Wrangler JL What do you guys think of these 9” Kiwi Master LED headlights 801A2C7B-DD85-4BA4-B897-4E14CBBA84B9
Jeep Wrangler JL What do you guys think of these 9” Kiwi Master LED headlights 8030E207-AAF7-4D1C-B814-E399D428B8B1
Jeep Wrangler JL What do you guys think of these 9” Kiwi Master LED headlights A7D2C032-9F66-440D-A1F5-B9E607182DFD
blnewt
New Mexico
Just ask @cosine he knows!
Looks like nice output and a pretty distinct cutoff, look to be aimed pretty low, might want to raise them a bit (unless your JL is on a downward slope there). Do those have amber turn lights too?
Arterius2
Arterius2
Jerry
Vancouver, BC
Finally weekend and sunny day out to see the LEDs and the Jeep in all its glories.:giggle: These don’t have amber turns. The low cutoff was due to me installing washer preemptively but actually didn’t need them, I took them out after and it’s perfect.
Arterius2
Arterius2
Jerry
Vancouver, BC
Review going here.
Jeep Wrangler JL What do you guys think of these 9” Kiwi Master LED headlights C5790946-6709-4DDC-B0BB-55F0C0C88E91
Arrived in box, no instructions, first step was to weather-seal the connectors better using shrink wrap tape and crimp the DRL(red) cable to extension (white) cable provided. Connects directly into the original halogen plugs, except for the DRL cable.
Jeep Wrangler JL What do you guys think of these 9” Kiwi Master LED headlights 5973125F-0703-4CD9-8350-D4B068A71EBD
Jeep Wrangler JL What do you guys think of these 9” Kiwi Master LED headlights 87D86EC0-6BA7-449C-9C8F-26758B7A608B
Remove front grille and detach stock halogen headlight assemblies. (held by 3 bolts each)
Jeep Wrangler JL What do you guys think of these 9” Kiwi Master LED headlights 613D7738-DDE4-4A09-AB35-FBB9712D0515
Jeep Wrangler JL What do you guys think of these 9” Kiwi Master LED headlights BA6BD958-1960-402F-B77B-5C8E196D4FAB
Would like the ability to turn on-off my halo at will, so I joined both DRL extension cables together and crimped it into my Aux 4, feel free to splice it into your fender DRL or ignition if you wish.
Jeep Wrangler JL What do you guys think of these 9” Kiwi Master LED headlights 864AA500-99DE-4681-9318-40CCC2C60FCF
Jeep Wrangler JL What do you guys think of these 9” Kiwi Master LED headlights 552986ED-37D7-46D1-B762-F4BA96510C92
Will be temporarily hooking the DRL to aux until I swap out the halogen fender housing for LEDs later. Ignition/Latching/Last-State-Recall, works just fine and functions like halo DRL, can also turn it off whenever I want.
Jeep Wrangler JL What do you guys think of these 9” Kiwi Master LED headlights 9FDCD452-1D40-4D5F-A843-9CA64A26EB81
Jeep Wrangler JL What do you guys think of these 9” Kiwi Master LED headlights 1EC393CF-C49A-4F00-9409-EBC358FBB7E0
You can adjust the headlights by adding washers behind the bracket.. plastic washers in photo. I first installed washer preemptively but found I actually didn't need them, they are aimed pretty low as is.
Jeep Wrangler JL What do you guys think of these 9” Kiwi Master LED headlights 770FC28C-815D-4976-8354-CA8B64C81BE6
Jeep Wrangler JL What do you guys think of these 9” Kiwi Master LED headlights 1B5B3DC0-791E-40E8-BFCA-15C8132ECA1C
Jeep Wrangler JL What do you guys think of these 9” Kiwi Master LED headlights ED8DDA7E-6131-4741-AE6C-6DD16907F208
Secure headlight assembly with the 3 bolts from stock housing.
Jeep Wrangler JL What do you guys think of these 9” Kiwi Master LED headlights F0425360-5026-4010-856C-BC9BBD0B148D
Jeep Wrangler JL What do you guys think of these 9” Kiwi Master LED headlights DB2487D2-2334-4AE0-9464-EDCE42EED34A
Jeep Wrangler JL What do you guys think of these 9” Kiwi Master LED headlights 712FF08E-BF31-4BC9-A891-2ED61EBF8A30
Halo+Low beam turned on:
Jeep Wrangler JL What do you guys think of these 9” Kiwi Master LED headlights 6B657380-9F20-4CF7-A428-A9F459C59458
Jeep Wrangler JL What do you guys think of these 9” Kiwi Master LED headlights 3665060E-97B1-4B03-A0BD-32CEA5FF410D
Halo+Low beam+High beam turned on (low beam will remain on during high beam), love this feature, won't sacrifice near-field illumination during high beam operations.
Jeep Wrangler JL What do you guys think of these 9” Kiwi Master LED headlights C384B942-196C-46D2-B6D3-37B6AD6B68FC
With washers, the cut-off is a bit low, note my parking garage is on a slight incline downward.
Jeep Wrangler JL What do you guys think of these 9” Kiwi Master LED headlights CE9B74C4-95C5-4746-A127-F4669FDF8086
Took washers off, nice and sharp cut-off, super bright.
Jeep Wrangler JL What do you guys think of these 9” Kiwi Master LED headlights D7D8D872-F1EF-45F4-9E0F-40CE173DC7FD
Tada.. Everything back together and under the sun..
Jeep Wrangler JL What do you guys think of these 9” Kiwi Master LED headlights 1AB640A2-B316-4BF9-A944-0E93F3997E16
mwilk012
Service
Review going here.
So you attached the DRL wire to one of your aux switches? Did you not want to wire it to the fender DRL for some reason?
mwilk012
Service
Disregard, now I see your text in there amongst all the pictures.
