What do I need to know before putting a JL Rubicon Suspension on my JL Sport S.
zeebo56
Zee
los angeles
2020 jeep wrangler unlimited sport
Do you know if the stock Rubi LCA's are longer than a stock Sport or the same?
I believe they are the same. The shocks and springs are different.
Well my phone had delayed showing the previous message.
RickyMo
Rick
Kihei, HI
2019 Jeep Wrangler Sport 2 dr
Retired Firefighter
Got it done this weekend and I’m very happy with it. I got about an inch front and rear (no spacers, just the springs, shocks and longer Mopar lower control arms) and it drives great. A buddy helped me and it took about 7 hours total. We’re very methodical and had to break it up over two days due to other commitments. The hardest part was probably breaking the LCA bolts loose. We did overtorque everything and had to back and redo that part. We confused Nm with ft. lbs and didn’t figure it out until we started to torque the LCAs. These are the part numbers and I’m not sure if they came off a soft or hardtop Rubicon etc:
Springs
Front driver 68253659AD
Front passenger 68253660AD
Rear driver 68253590AA
Rear passenger 68253591AA
Shocks
Front P68330209AB
Rear P68330210AA
The before/after pics aren’t the best as the before pic is with 245s and after is with 285s. Also, Plasti-dip doesn’t hold up well to tire swaps. Thanks very much for the advice on this stuff guys, especially the LCA advice!
Your Jeep looks great! I know th
Thats what I was guessing...thanks!
Knel6
Kody
WA
2020 Jeep Willys
Stock Rubi LCAs are the same part number as sport trim levels. I got the set with Rubi takeoff suspension and they were identical.
RickyMo
Rick
Kihei, HI
Retired Firefighter
Thanks for reply.
omnitonic
Michael
Southwest Virginia
2021 JLU Willys in Sarge Green
truck driver
7) after you put the new springs in, you’ll have push/pull either the axel or Jeep to line the trackbars back up (pushing on the tub of the Jeep or turning the steering wheel will accomplish this and it’s much easier to do with two people)
After spending a lot of time trying to get my head around what I'm about to do, I still have no idea what this means. Line back up how? Every trim level has the same fixed track bars, and these springs are staying within the spectrum of possibilities that the overall suspension design accommodates, so it seems like the track bars will just eventually do their thing with no intervention needed.
11) the alignment nubs on the top spring isolators will no longer be correct...you’ll have to trim it off
**EDIT** It appears that the spring isolators may be universal across the different springs so this may not be necessary. Compare your new and old springs (remember they are corner specific) and check to see if both ends of the springs line up in the same spot. If they line up...no trimming necessary.
I don't have a clue how to do an alignment, or what an alignment nub is. Line what up how why? The list here in this older post is basically the only place I've ever seen anyone mention this detail.
My only other caution flag is the LCA issue. Some guys had hideous problems, and some guys had no problems at all. Some guys swapped LCAs, some guys didn't.
The suspension height I will get is within the spectrum of possibilities they engineered into the design, so it seems like the standard LCAs will probably be fine. All of this is complicated by the fact that I am lifting something that is already heavier than stock. Maybe without the bolt-ons it would have messed up the geometry, but with the bolt-ons it will be back to stock. Maybe I need a spacer to compensate even more, maybe I don't.
I've got spacers and longer LCAs coming, and I'm hoping I can just figure it out when I start wrenching.
Dr. RGB
PA
No longer own a Jeep
Check here: https://www.jlwranglerforums.com/forum/threads/rubicon-suspension-on-2-door-sport.40700/
All of your questions should be answered.
TA1ton
Travis
Tyler, TX
2018 Jeep Wrangler JLU Sport S
Civil Engineer
You are correct...the track bars are the same across trim levels. But the track bar travels in an arc and the longer springs move the axel away from the frame vertically. So as your track bar travels down it’s arc, the bolt holes on the axel mount and track bar will now be slightly off...not too bad, but usually enough to not be able to get your bolt in. So you have to move the axel or frame to get them to line back up.
Your top spring isolators (the rubber pads on top of your springs...pic attached) have a little nub of rubber that sticks into a hole in the upper spring bucket to properly align the isolator so that pressure from the spring is evenly distributed to the bucket. If this isolator is misaligned, it can cause issues with the suspension such as spring bow. Some bow is acceptable but in a perfect world, there would be none. But as I said in my post, this may not be necessary and the ends of all the different springs may be in the same position relative to top and bottom.
Hopefully that answered your questions.
BGB9
Brandon
Nolensville TN
2019 Jeep JLU, 2013 Jeep jku
I see this has been covered over and over but the more I read the more I get confused.
I’m stuck on what spacer length to get. I recently purchased a set of rubicon springs 660/661,590/591 with the shocks. I have also purchased the longer mopar LCA 68322798AA
This is going on a 2019 JLU sport 3.6 with tow package. I’m looking to level it out as much as possible but am fine with a real slight rake if at all. What I don’t want is the back end to be higher.
The options that I’m looking at is as follows:
Option 1- KitTeraFlex JL/JT EcoDiesel 1” Coil Spring Spacer Adjustment Kit for the front and TeraFlex 1155120 Rear Load Level Kit of .5 in the rear.
Option 2- KitTeraFlex JL/JLU: 0.5” Front & Rear Spacer Load Level Kit
Option 3- Rough Country 3/4 coil spacer for the front.
Any help or other advice/options with this would be greatly appreciated!
blnewt
New Mexico
Just ask @cosine he knows!
Rubicon springs for approx 2" lift, longer Mopar lift LCAs and FOx 2.0 shocks for 0-1.5" lift.
I put .75" Rugged Ridge spacers (were for a JK but worked fine for the JL) in the front to gain some height back after installing steel bumper & winch. I have since ditched the spacer and the 295/70 tires and added a Teraflex spacer kit (it's a 4dr spacer set, 2" F 1.5" R) for my current 315/70 tires, the 4dr spacer set gets rid of the rake I would have had if I used the shorter 2dr set.
Top pic is prior to the .75" front spacer and prior to winch/bumper
Second pic .75" front spacer worked well to level it out after the heavier front items were added.
and now a pic of it currently
Jeep Wrangler JL What do I need to know before putting a JL Rubicon Suspension on my JL Sport S. IMG_0253.JPG
Jeep Wrangler JL What do I need to know before putting a JL Rubicon Suspension on my JL Sport S. IMG_0502.JPG
Jeep Wrangler JL What do I need to know before putting a JL Rubicon Suspension on my JL Sport S. 0209231420a
