What did you do WITH your Jeep today.
omnitonic
Michael
Southwest Virginia
2021 JLU Willys in Sarge Green
truck driver
Well one hour later have my 1st Rear Hard Rock LCA skid installed. 3 more to go. :whew:
:swear::swear::swear::swear::swear::swear::swear::swear::swear:
The front ones were even more fun. Worth it though. Also, I did paint mine to match the Rancho stuff, so I'm kind of glad you didn't.
omnitonic
Michael
Southwest Virginia
truck driver
I decided to see how the drone would cope with an extremely windy day. It's rated for winds up to about 24 mph, and I'd say there were gusts considerably stronger. There are definitely some glitches in the video where I can see the propellers or the arms, which hints at crazy bad things happening in the gusts. In spite of that, the video is amazingly stable. I love this thing! Jeep + Drone = Happiness.
If I get my Jeep back in time, and if the weather permits, next weekend, I feel confident enough to fly down to the treetops below the 700' high cliff, and get some video showing the crazy place I'm standing in context. I may be going on my first wheeling trip with a friend that time too.
NewJLU2019
2021 Rubicon Unlimited 2019 Sahara Unlimited
Retired Now
I thought about it. I asked you what color you used. Decided to keep them and to really match the front DV8 skid. I had to remove the DV8 so I could get to the drivers side LCA bolt.
omnitonic
Michael
Southwest Virginia
truck driver
I didn't put two and two together.
I like that DV8 diff skid. Man, that thing is pretty beefy! I probably would have bought that one instead of the RC, but I can't really complain about how the RC has held up to abuse.
I had to remove my front diff skid and my FAD skid to get the fronts installed. It took four times longer than the rears. Worth it though. I already screwed up all that fancy red paint on my first wheeling trip today. It felt marvelous! 😁
OMTBiker
Derek
Ohio
2021 JLUR White | 2021 JLU 80th Snazzberry
Information Technology
Went to the UP over the weekend, pulled the camper and stayed at the KOA in St. Ignace. Took the ferry to Drummond island and hit part of the South Marblehead loop Jeep badge of honor trail. We came across a motorcycle that got stuck, pulled him out, then followed him back to the road to ensure his safety.
INCRHULK
Lance
Canada
litwphoto.com
2019 Wrangler Unlimited Sahara
Team Lead, Information Technology
How is the Cricket? I've been eying it, or an Opus lite. I need something that my 12yo dog can climb into, which eliminates many of the RTT campers.
INCRHULK
Lance
Canada
litwphoto.com
I ran Lingham Hydro line with my club Sunday. Annual fall colours run.
OMTBiker
Derek
Ohio
At this point I would not recommend Taxa Outdoors or any of their trailers, mine came with a bad axle brand new and the replacement axle failed on this trip which was the first trip since getting it replaced. Their customer service is very slow to respond, if they do respond, and honestly not worth the money they want for them. I had to reach out to Lippert for the axle replacement as Taxa would not respond or acknowledge the issue after several emails.
Our first and second trailers were an InTechRV Flyer Pursue then a Sol Dawn Rover, which is far above the Cricket in quality and less expensive. We loved the Pursue but not being able to stand up and no onboard water got old, we decided to go up slightly in size which is why we went with the Dawn. The Dawn was only 2ft longer, I was able to stand up, had onboard water, and was still relatively light weight. We got rid of the Dawn as we had to store it over an hour away which resulted in us never using it otherwise, we would have kept it. I am regretting that decision.
We had the following requirements when looking at the replacement for the Dawn: onboard water, ability for me to stand up inside, and fit in a standard garage. Taxa was the only trailer that met those requirements which is why I purchased it, I did my research and knew of the usual issues common to all their trailers but bad axles was not one noted. Research brought up the haphazard support and customer service which I accepted as long as there were no know major issues.
Side note; after I made a comment on their Facebook group (created by the company) about the second failed axle, my post was deleted and I was removed from the group. That should speak volumes about the company and how they feel about customer service.
My apologies for the long response, at the end of the day no camper/trailer is built very well and they will all have issues but some are worse than others.
Heimkehr
Pennsylvania
2021 Jeep Wrangler Unencumbered
Is installation of the front skid plate merely a matter of loosening bolts where required? I like to review installation docs prior to purchasing accessories like this one, but only the manual for the rear diff skid plate is evident on the DV8 site. TIA.
NewJLU2019
Retired Now
You remove the 4 factory bolts and reuse them. The left bracket goes on drivers side over axle and connects. The right one is passenger side. The lower bracket goes over backside of diff. Its easy to install once you get lined up. I had to remove mine to get to the LCA bolt to remove and to be able to use torque wrench. The 2 brackets go over axle and connects bottom and top of skid plate.
NewJLU2019
Retired Now
I have 300lb Impact wrench and cheater pipe for socket wrench and neither will back front LCA bolt loose. The socket and cheater pipe removed the rear LCA very easy. WTF is the deal ? The rear loosened right off with cheater pipe on wrench.
hoag4147
Rick
DFW, Texas
2018 JLU Sport S / GMC 1500AT 4x4
NewJLU2019
Retired Now
Jim Marsh Chrysler Jeep
