Tl5glenn
Where did you purchase? I only see this for the JK... thanksInstalled a FOX ATS steering stabilizer.
How many did you put in wheel wells?Installed some rock lights.... and by some, I mean 16.... I figure why light up the trail for just myself when I can light up the forest for everyone?
Looks fantastic!Got it lifted, tires, front and rear bumper.
@Northridge4x4 has them in stock. Just give them a call.Where did you purchase? I only see this for the JK... thanks
Looks friggin sweet! Love the Sting Grey.Stubby and winch install today... still need to add lighting and tension the rope...
Check with JKS or synergy - I saw a video not long ago installing the relo bracket on a JL but I can’t find video or remember brand.Yead the difference is night/day. I found myself going 10-15mph faster than I normally do on the freeway and not even noticing it. The steering just felt tighter/more controlled.
Worth every penny unless I'm smashing it on rocks once a month! I really need to find a way to move it up & out of the way, or pull it off when I go play in the rocks.
Was it on the ATS specifically or just a generic stabilizer? The ATS has a special joint on the axle side that requires the use of their bracket(Not just a hole that you can mount on a stud.) I'm thinking I may be able to fit a JK ATS since I have a raised trackbar/flipped draglink in the front. I need to measure the tie rod to see if they are the same diameter.Check with JKS or synergy - I saw a video not long ago installing the relo bracket on a JL but I can’t find video or remember brand.
It was the OEM stabilizerWas it on the ATS specifically or just a generic stabilizer? The ATS has a special joint on the axle side that requires the use of their bracket(Not just a hole that you can mount on a stud.) I'm thinking I may be able to fit a JK ATS since I have a raised trackbar/flipped draglink in the front. I need to measure the tie rod to see if they are the same diameter.
