km58501
What size tires are you running? You 2dr looks great.I installed a set of HANKOOK DYNAPRO LT295/75X16 AND the DYNOMAX "TURBO" MUFFLER--
Sweet sound-and fits perfectly, even though it's designed off the JL 4DR
W.E.
W.E.
Brilliant!Simple $1 fix to a really annoying problem.
I had heard rumors 16” wheels were tight around the Rubicon rotors. Do you have a good amount of clearance?Thanx--the tires are HANKOOK DYNAPRO MTs--LT295/75X16--LOAD RANGE "D" --ON PROCOMP 16X8" alloy wheels-
They're a little over 32-1/2" TALL--AT 30PSI-
have agreat day
JIMBO
Any chance you could show us more pics of those awesome rock rails?!Maximus-3 stinger installed. Not just cosmetic like the JCR bolt on. The Max3 has 1/4 inch thick steel brackets that attach to the inner frame as well as the bumper.
What s this? Between the seat?Simple $1 fix to a really annoying problem.
I'm also running 16" procomp wheels on my Rubi (35" nittos). It's very tight around the calipers esp the fronts. I couldn't slide a credit card between the caliper and the wheel. they do fit and look awsome but very little clearance, peel and stick weights would be ripped off by the calipers. Fitment of 16" i believe is hit and miss. I dont think 15' would fit any Rubi regardless of BS. I've posted pics on this topic before but could post again if desired.Heh Heh, while I was installing the PROCOMPS--I also checked the front HD brakes on the JL RUBY and there's about 3/8 " clearance when the wheels installed-
i don't think 15" wheels would go, unless you had 3" bs-OR LESS
Have a great day-
JIMBO
hawttt!37” Nitto Ridge Grapplers and Fuel Assault Rims on a 2” Rubicon Express spacer lift
