EXPFDR
Upstate NY
2021 Wrangler Billet Silver JLU
Army Retired
I have the same lights but without the halo. How do you like the cut off for the lights?
It took some time to get use to the blue cut off line. After a year it doesn't bother me. Only thing I dont like is if you are going down a short steep hill. Cant see that far in front of you. But with highbeams on, lookout! Can see a country mile.
tk1700
Tom
New Mexico
2019 JLU Altitude, 2021 JLUR, 2016 Tundra
If oncoming motorists flash their headlights at you due to incorrect aim of the pax-side headlight, there is a possible fix here in the absence of the adjuster:
-Aim your headlights at a wall that you're parked maybe 20' away from, and place a piece of masking tape on the top of the beam cutoff of the driver's side light. Mark the center of the beam with a vertical line on the tape.
-Remove the grille again. (I know :()
-Loosen and/or adjust the three 10mm bolts that secure the right headlight in place on the vehicle. Have a few washers on hand to use as shims so that when the centered cutoff of the right headlight now matches the correct cutoff of the left light, the bolts may be tightened (with any necessary washer shims already installed) to secure the DIY adjustment in place.
I know the foregoing sounds a bit busy, but it's straightforward and should work. More to the point, we do have a responsibility to other drivers to not blind them with maladjusted headlights. 👍
I make occasional visits to a local U-Pull-It yard. If or when I find a JL that I want to cherry pick, and if I remember, I'll determine if I can snag an adjuster fitting for you.
Thanks for the suggestion. I haven't driven it at night yet, but the lights are at about 39 inches, so not too much over spec. I'll see how they work on the road and if I get flashed. Eventually I will get them adjusted. Thanks for looking for an adjuster!
Update: I called my dealer today about the missing adjuster. They were absolutely no help. I found a set of almost new headlights taken off a JT on Craigslist. I ended up paying $50 for the pair and am waiting for dark so I can adjust them.
1Evil55
here
2018 Sport
My voswitch taps into a fuse (I think #57h that only powers on my switches when the car is on. I tapped into that wire
I believe their suggestion is to use #52 fuse under the hood, passenger side. They will turn on any time the Jeep is on.
Twisted Patriot
SE Michigan
2021 Jeep Wrangler WILLYS
U.S. Military Vet, Former Corrections Officer, Current Maserati Claims Specialist
Added the Teraflex HD Alpha hinge reinforcement to the already installed HD Alpha carrier.. I was getting too much tailgate flex with these heavy ass wheels and tires.. now it's rock solid.. doesn't even move.. im happy with it.
Caliguy
Norcal
2022 Rubicon JLU
I think you’re right. #57 is the heated seats i think? I ended up tapping into both since I have two voswitches in my rig
redsyphon
North Florida
2018 JLU Rubicon
IT Project Manager
Got rid of the ugly junction box that I had my 12v panel and solar system in, and replaced it with a simple board and layout.
It runs the domestic, rear window interior lights, auxiliary 12v and USB connections, as well as the 200w solar panels atop the roof.
Jeep Wrangler JL What did you do TO your Jeep JL today? received_505564137587349
Heimkehr
Pennsylvania
2021 JLU 2.0T
I used my Dymo label maker to add a reference sticker to the fuse box lid.
Heady stuff! 😁
Jeep Wrangler JL What did you do TO your Jeep JL today? IMG_20220927_155702
JP29
Zach
Olathe
2020 JL Sport
Was hoping to do this with my old man (and his lift), but I got tired of looking at the box. Today I swapped the old beer can muffler for an Injen high tuck axle back. First had to loosen the OE clamp - 15mm, which I didn't have of course, so a trip to the hardware store was in order. Then getting the muffler off the rubber hangers, which was a massive pain.
Jeep Wrangler JL What did you do TO your Jeep JL today? 59562d96-711e-4039-a5d8-f1e231c69678
First one down.
Jeep Wrangler JL What did you do TO your Jeep JL today? IMG20220927123724
Oldie out. The thing was stuck pretty tight on the mid pipe, thankfully after a bit of garage door lubricant and physical persuasion it came off.
Jeep Wrangler JL What did you do TO your Jeep JL today? IMG20220927123845
New hotness. Be prepared - the instructions don't say whether it slips into the mid or over like the OE does. It's the latter, and my pipe needed a bit of convincing with pliers before it would slip over the mid. Also, the instructions say to use a 17mm socket on the replacement clamp, which is wrong - I should have tested the 15mm I had on hand. I guess now I've got one more socket though, so it could be worse!
Jeep Wrangler JL What did you do TO your Jeep JL today? 47bb29e3-156a-412a-b42b-84ebb9df60d5
Doesn't tuck up as high as I'd hoped, but it has much better flow over the OE with the massive pinch in the pipe, and the sound is great as well.
rscott91
Delaware
Jeep Wrangler Willys XR
Nooo! Just the spray gun. I air dry on the way home. Then use Turtle Wax ceramic spray coating with a microfiber towel.
Hey, just picked up my 23 Willys, and got some Turtle Wax Ceramic, how do you like it ?
Thanks
Slippery Pete
Zach
Central PA
2022 JLUW XR 2.0T
Thanks
I'm not familiar with other products so I can't compare it with others but it definitely looks good after applied and water beads off it pretty good.
