iddpaul
Paul
2020 JLUR
So had an interesting time...the ESS dash light came on, from posts on this site was pretty sure it's the Aux Battery. Put a meter on it, very low but decided to keep driving it for a while until I could get an appt with my dealer. Talked to the service dept. said since it's a 2020 they were surprised that the battery lasted this long...what? They then said they'd need it for at least a couple of days to run diagnostics before being able to cover it under warranty....what? (Days..? and couldn't get an appt. for a week and a half)
Problem solved, tried to start it this am, received all sorts of dash lights, was in park but the system said I was in "D"....jump got me going but decided my time was worth more than waiting on the dealer.
Picked up a replacement Platinum AGM AUX-14-1 (approx. $115). Looked at the three possible ways to replace the battery - (1) remove the fuse box and come down from top, (2) remove the Fender or (3) remove the fender liner and come up from the bottom. Didn't want to mess with anything from the top so did the "super easy" Fender Liner removal to get access.
If you're replacing the battery I'd highly recommend this method. Removed the front passenger wheel, removed the 5 fender liner bolts and approx. 7 "push-in" plugs, drilled the three edge plugs and then just slipped the liner out. (You have to drill out three of the liner plugs as they go through the liner, the rest the liner slips behind). Dropped the battery holder, replaced the battery, tested the start - all good, replaced the liner, put in new "push-in" plugs, bolts and tire. Everything working perfectly, so decided to replace the main battery with a deep cycle just to stop the madness. (A smaller H6 will fit but used an H7).
Jeep Wrangler JL What did you do TO your Jeep JL today? JL Fender Liner
Jeep Wrangler JL What did you do TO your Jeep JL today? JL Fender Liner 1
bdb5430
Atlanta, GA
2021 Wrangler Rubicon
Installed Armorlite flooring. Pain in the damn ass because I kept popping out the u clip in the center console, dropped the shift knob retaining screw into the console, and then the compressor under passenger seat needed a .5ā€ spacer that was a bear to get lined up under the legs and flooring. Worth it though.
Jeep Wrangler JL What did you do TO your Jeep JL today? 6C0AAED2-31A9-4FDE-A68E-D778310DA06C
Jeep Wrangler JL What did you do TO your Jeep JL today? 0E63DAB7-E1C3-4C23-B821-09ED43E46C6F
Jeep Wrangler JL What did you do TO your Jeep JL today? 19D1534C-951A-46A1-A531-E30C4626893C
Jeep Wrangler JL What did you do TO your Jeep JL today? B4113E37-456B-4F99-AF07-E2DC51496A07
Jeep Wrangler JL What did you do TO your Jeep JL today? EDF1BCF9-5E2E-46E3-A8B6-8C8FD5677E57
gustomatic
Harrisburg, PA
2021 JLUS4xe
Sprayed the giant muffler with high heat flat back. Super glad I did.
installed 392 rubicon decals with topo overlays.
installed teraflex quick release 3rd brake light mount on stock tire carrier
eagerly waiting for ups man to drop off my falcon steering stabilizer
Where'd you get that 3rd brake light mount? I can't seem to find it.
WRGLR-JL
PA
2022 Willy's 2 door
Lol. A hair dryer will help.
In saying all that though. I hated the plastic sill guards. Left a door gap and stored shit under them. I ended up just masking off and bedlining. Lol.
I want to thank everyone who helped to get my head straightened out regarding my misaligned driver side door sill. With patience and $10 worth of 1/4" super strength molding tape from AutoZone I can proudly enter and exit my vehicle again!! LOL.:dance::dance:
Caliguy
Norcal
2022 Rubicon JLU
I had to call Teraflex and order it separately.
Thats the Teraflex HD tire mount
I donā€™t have the whole tire mount. Iā€™m using a Chinese replica of the mopar relocator bracket and reinforcment hinge with my stock tire carrier. I added just the Teraflex third brake light mount to my factory rear camera cylinder
I also finally installed my new steering stabilizer. I wanted fox but the one I received from Amazon was obviously defective and I didnā€™t like the adjustment screw. So I bought a falcon one instead. Installed very easy. I recommend ordering the old style bolt instead of using the one supplied for the shock. Since the rest of the shocks are fox, this is what happens when a falcon and a fox have a baby (or atleast put a fox sticker on a falcon shock to match the rest)
Jeep Wrangler JL What did you do TO your Jeep JL today? FDFF2032-D6B3-43FB-9FF0-DA2E78B681F2
NewbJLUOwner
JLU Rubicon Diesel 2022
Scarlett šŸ’• šŸ˜ŽšŸ”„
Rainy weekend, good time to do some minor mods & maintenance
1) added rear LED Brake Lights
2) bunch of inexpensive mods, now I have my cup holder back
3) replaced the air filter on my Eco-Diesel @ 7200 miles, no haters plz
4) 35" tires, new wheels, & 1st Oil Change this week coming soon
Jeep Wrangler JL What did you do TO your Jeep JL today? 20220827_134351
Jeep Wrangler JL What did you do TO your Jeep JL today? 20220827_115551_1
Jeep Wrangler JL What did you do TO your Jeep JL today? 20220827_124521
Jeep Wrangler JL What did you do TO your Jeep JL today? 20220827_141845
Jeep Wrangler JL What did you do TO your Jeep JL today? 20220827_141924
Jeep Wrangler JL What did you do TO your Jeep JL today? 20220827_141952
Jeep Wrangler JL What did you do TO your Jeep JL today? 20220827_141936
Jeep Wrangler JL What did you do TO your Jeep JL today? 20220827_142057
Jeep Wrangler JL What did you do TO your Jeep JL today? 20220827_142220
Jeep Wrangler JL What did you do TO your Jeep JL today? 20220827_142556
Jeep Wrangler JL What did you do TO your Jeep JL today? 20220827_143720
Jeep Wrangler JL What did you do TO your Jeep JL today? 20220827_143726
Jeep Wrangler JL What did you do TO your Jeep JL today? 20220827_143816
Jeep Wrangler JL What did you do TO your Jeep JL today? 20220827_145330
Jeep Wrangler JL What did you do TO your Jeep JL today? 20220828_152537
Jeep Wrangler JL What did you do TO your Jeep JL today? 20220828_153038
Jeep Wrangler JL What did you do TO your Jeep JL today? 20220828_153106
Jeep Wrangler JL What did you do TO your Jeep JL today? 20220828_153116
Jeep Wrangler JL What did you do TO your Jeep JL today? 20220828_153241
Ponce
Eastern NC
2018 Rubicon JLU
Retired USMC. Currently USMC pilot instructor
DV8 sway bar disconnect plate.
DV8 FS-15
Warn VR 10s
Factor 55 ultra hook.
Jeep Wrangler JL What did you do TO your Jeep JL today? 20220828_074601
Jeep Wrangler JL What did you do TO your Jeep JL today? 20220828_080325
Jeep Wrangler JL What did you do TO your Jeep JL today? 20220828_160351
Dwightrerskine
Dwight
Franklin, TN
ā€˜22 JLUR XR, ā€˜20 Q7, ā€˜19 S5
Applied Gtechniq C4 Permanent Trim Restorer to all the exterior plastic, including the wheel wells.
Applied Gtechniq C5 Wheel Armour to the front and back of the wheels. (No pic)
Detailed the interior
frank-o
Frank
USA!!
392 SOT, JLUR SOT, Prior JLUR Sting, 10thA JKUR
Jeep Wrangler JL What did you do TO your Jeep JL today? 0014868D-32AD-4A50-A41D-5CE18B4CF66B
Those seats are fire!
jhackathorne
Denver
'21 JLUR
I think Iā€™m misreading this. Did you accidentally type that you used wheel armour on the back of your tires? Or was this supposed to be the front tires and rear tires. So you did all 4 tiresā€¦.
AZ Hella
Sonoran Desert
JLUR
Final prep for our Montana trip next week.
changed the oil, transmission fluid (MT) and transfer case fluid. I had to file some bolts back into shape before I could remove the skid plates.
Dwightrerskine
Dwight
Franklin, TN
Sorry for the confusion! C5 Wheel Armour on the wheels, not tires. C5 is like a ceramic coating for wheels.
I had to take wheels off to coat the well liners with C4, so I did the inside of the barrel that usually get filthy with brake dust (and canā€™t easily be reached with a brush).
The tires are actually quite filthy. Iā€™ll clean them with Griotā€™s Rubber Cleaner tomorrow and then dress them.
