Spearmin
Nothing look better than a pair of STT Pros. Noisy as hell when they wear down a bit.2” leveling kit on 37s with a livernois performance tune!
The concave look on wranglersNice!! I’m leaning towards 312s myself. In NY also, Queens. Where are you located? Any good wheel shop you recommend?
Wow! Stunned at the bad customer service from Adams. I thought they were the gold standard…guess not.Update On Adams 1350 Front Driveshaft:
Called Adams this morning to discuss their transfer case yoke interfering with the shift linkage arm and was surprised to hear they know about but don't really care...I was told yeah, on the JK's, JL's and JT's it often happens and you will have to 'trim' the shift linkage arm. I said that would be easier to do before the yoke is on, red Loctited and torqued to 166 ft pounds-I said maybe you should at least make people aware this could happen so steps could be taken before installation! I am leaning towards replacing Adams yoke with a DANA 1350 that will likely fit properly and probably has the protective flange to protect the now exposed output shaft seal...
BTY Dana's instructions on their 1350 aftermarket front axle say to use BLUE Loctite and torque the nut to 150 ft pounds...
Adams Yoke: Less than 1/16" clearance till it hits linkage arm and note no shield to protect exposed output shaft seal.
When I ordered this Adams shaft I specifically asked them to pay special attention to high-speed balancing of the front driveshaft as it now couples to a 4.88 DANA UD44 without FAD. After the customer service I received when I called this morning, I had doubts they did this either...So I took the new driveshaft down to a local shop that specializes in driveshaft balancing and told them I wanted it checked and balanced if needed. I also told them I would be happy to pay the same for just a check as for a full balance, I was with the tech when he first spun it up and it was NOT balanced, after balancing he took it to the equivalent of 100mph and smooth as can be. $120 well spent!
Adams after proper balancing: Smooth at all speeds!
Will NOT be using Adams for the rear driveshaft...
Still waiting on it I drive my spouse’s 2020 2dr Willys till it arrives probably some time next yearThis is a fun thread I’ve seen on a few other forums. Can be anything from mods to drives, to washes, etc. pictures are always a plus!
So what did you do to your Jeep today?
Looks great!Finally pulled the trigger on new wheels (Method Race Wheels NV 305). Really like the look. Next step, lift her.
They wont take them back? What other company is thereUpdate On Adams 1350 Front Driveshaft:
