Mx5red
Paul
San Diego
2020 JTR, 2020 JLUR
I don't know where else to put this, but it is Jeep related!! I'm a Michigan fan living in LSU County. My father in law (from here in Baton Rouge), had this custom fire pit built for me. Block M on 2 sides, and 7 slot grill on the other 2 sides. Stainless rack for ribeyes.
That might be the sweetest thing I’ve ever seen. Go Blue!
Gladius Nova
Gladius
2021 JL
So over the last week:
17x9 Method 312’s
37x13.5r17 Toyo Mt’s
Steersmarts Yeti Front TB
Metalcloak Rear TB
Metalcloak Front LCA’s
Teraflex Shock Extensions
Teraflex Swaybar Links
Teraflex 1.5” Spacer Lift w/ TF Bump Stops
Fox ATS Stabilizer
Rugged Ridge Tire Carrier Set up
Tazer
Damn that's a good looking Jeep!
mferrara91
Chester County, PA
2021 JLU Sport Altitude
Quadratec Stealth Light Bar installed.
Jeep Wrangler JL What did you do TO your Jeep JL today? 94CB2645-8872-4C0B-A39B-07163B31338E
Jeep Wrangler JL What did you do TO your Jeep JL today? 8DB6C747-DEA2-44FB-8482-93C32CCC1B0A
Jeep Wrangler JL What did you do TO your Jeep JL today? 8A2B00A0-7F78-4161-B595-3BC987940991
mferrara91
Chester County, PA
Finished up my weekend project. Got these Motobilt rocker armor a year ago and just now got around to putting them on. I’m gonna run them along with the stock Rubicon rail. They’re painted with steel it for now. I actually like the way that the steel it color goes with the black and stingray so I think I’ll keep it that way. I am going to add probably a tube welded to the Rubicon rockers at an upward angle and then put a plate on top of that to use for a step and to strengthen it. And then I’m going to make some quick removable steps similar to the last picture.
Jeep Wrangler JL What did you do TO your Jeep JL today? 4D6C4148-6F61-4948-B3C8-86E03C189285
Best part of these pics is those 2 awesome yellow labs.
MORubi
Kansas City MO
2018 Red JLUR, 2014 Jeep Grand Cherokee
Construction
Thank you! Been a long time coming. Waiting for it to get built to waiting for the tires to get in. Who knew that I would wait 8 weeks on tires. I would have ordered them when I did the Jeep.
WOwen
William
Chicago
2018 WB Hellcat, 2016 Wrangler, 2021 392 Wrangler
KMC Technic powder coated in Forged Charcoal with Center caps in Satin black wrapped in 37 Mickey Baja Boss A/T. Pics don't do her justice but my vision is coming along.
Jeep Wrangler JL What did you do TO your Jeep JL today? Screenshot_20211017-082733_Messages
Jeep Wrangler JL What did you do TO your Jeep JL today? 20211017_081721
Jeep Wrangler JL What did you do TO your Jeep JL today? 20211017_081505
mferrara91
Chester County, PA
Looks really cool! Does it light up the trail well? Any reflection off the windshield?
Oh yeah, it lights it up pretty good. Went on a trail with my son and his friend last night and it was like daytime. There is very little glare on the windshield. If you don’t push it all the way up and tighten during installation, you could get some light bleed. Definitely well worth the money and an easy install.
MyDaughters20JL
WA
20 JL Sport S
I'm not gonna lie, did this all yesterday....and I'm still sore (I guess that's what happens when you get old)
1) installed my ARB double compressor on the Grimm offroad bracket below the brake booster
2) Finally installed my Winch
3) began the wiring & started to install my light bar, only to find out I've got a couple brackets that don't work with my bar...pre-wired everything so when the brackets come in, all I"ve got to do is mount the bar & connect the lighting.
I'm surprised how well the winch fit in the bumper & how low it sits (badlands apex 12K winch in a westin WJ2 bumper
bgrex
NJ
JLU Sahara Altitude - Sting Gray
Swapped out the side mirror caps with the OEM export version to add signal lamps, and may have gotten a little carried away with the additional lighting. Hardware installed today, wiring still to be done. Baja S2 combos to light up the side blind spots will be controlled by aux3, 3/4” smoked amber led marker light will tie in with the fogs, and another 3/4” smoked white led underneath the mirror that will serve as a puddle light that comes on with the courtesy lights at unlock. Install not hard but involved a bit of cutting/shaping the caps and some of the mirror support structure with a Dremel. I’ll post again once I have a chance to run the wiring.
Jeep Wrangler JL What did you do TO your Jeep JL today? 44A043BE-E47A-45FF-8AF6-03CA75225CF7
Only took 4 months to finally find time to complete the electrical work on this side mirror project, but got it done this weekend (wiring was a tedious pain in the ass, but I’m happy with the result). Courtesy light underneath (operates in-sync with the dome light at unlock), turn signals, Baja S2 as ditch lights (Aux3), and amber markers (ties in with parking lamps). The Bajas are compact but generate great light on the edges - will be great for trails.
Jeep Wrangler JL What did you do TO your Jeep JL today? 8A055453-D516-4CB6-9BA7-DFB1C01C817E
Jeep Wrangler JL What did you do TO your Jeep JL today? C80B8624-3A10-4F51-A595-BB0FEA604AB0
Jeep Wrangler JL What did you do TO your Jeep JL today? 3D309CE0-B0DD-451B-A7AC-33E790B98726
Jeep Wrangler JL What did you do TO your Jeep JL today? FDFD5754-6339-41D9-BCBC-41AAA443B001
Low beams + fogs (without the Bajas)
Jeep Wrangler JL What did you do TO your Jeep JL today? 8AC178BF-7351-48EE-9366-43D380FC1BF6
Low beams + fogs + Bajas
Jeep Wrangler JL What did you do TO your Jeep JL today? E5CF9690-E3EB-4740-831F-2D0CA8287192
High beams + Bajas
Jeep Wrangler JL What did you do TO your Jeep JL today? 33F5BE74-A34B-4FA1-B114-82FD8F4D6118
