rubiRI77
scituate, ri
21 Rubicon two door. 2.0 Turbo.
I've already installed the Curt Class III hitch, and have the Quadratec harness in my To Do box. Concerning the CANBUS wire run from the rear of the vehicle to the battery, were you able to tuck it into or along the frame rail in order to provide some degree of protection? And how/why was the wire loom addition needed? TIA.
The adapters are more expensive than the speakers. Interesting. 🤔
I've the Infinity Reference 3032s on the dashboard. They provide a remarkable improvement in sound quality. I may have to do the same with the 6532s in the soundbar. đź’µ
Per the directions the wire going to to the battery installs along the factory wiring/gas line (at least I think some of it was gas line haha - it had heat shield on it) it comes out very clean and plenty protected enough in my opinion. I did use stainless steel cable ties at the heat shield part just for good measure. I figure if the factory put the heat shield material there then I don't want a plastic zip tie gettting fried. I tucked the trailer wire up on top and kind of behind the heat shield the best i could and then used the metal cable ties to snug it up. (the cable ties are from home depot in the electric section) This is part of the reason that I added more wire snake skin (or wire loom depending on what you call it) In the middle. They did such a nice job putting the wire loom on everything but left the middle exposed. Not sure why so I added more so the entire thing was covered. This long winded explanation will make sense once you do it. Basically I just followed the directions (which they were very good in my opinion) I just added a little extra zip ties, etc. here and there to make it extra safe and as neat as possible. It's not a bad install so have fun with it! (Full disclosure I do have a two post lift at home so I am cheating haha!)
rubiRI77
scituate, ri
Today was skid plate day!! Rancho Diff sliders, Evo Fad/steering stabilizer skid, and Hard 4x4 rear lca's. TNT customs engine/trans skid is on order too!
Jeep Wrangler JL What did you do TO your Jeep JL today? FF8ADC74-1942-4340-A515-8E77075391C4
Jeep Wrangler JL What did you do TO your Jeep JL today? F983818B-BCD5-42D7-A6F4-79248605F3DB
Jeep Wrangler JL What did you do TO your Jeep JL today? 90FBD026-44A3-45BC-A8D1-04BF29F01B21
Jeep Wrangler JL What did you do TO your Jeep JL today? A89A0441-C6EB-4A09-A006-CF754A56E40C
RubiSRT
Iowa
2018 JLUR & 2018 Dodge Durango SRT. Wife has 2019 Jeep GC Limited X
Switched out factory Rubicon hood decal for some orange accents/outline and digital camo. I didn’t like the red. Added matching side vent. Tinted front two windows to match factory tint. Put wearthertech non drill mud flaps on.
JeepAustinWeird
Austin, Texas
2018 JLU Rubicon
Jeep Wrangler JL What did you do TO your Jeep JL today? 1A0D5BD8-52B1-4B50-BEF8-E83EFEA2EA47
Looks nice. From where did you get the new decal? Did you install yourself and if so how did (tips on process) you remove the factory one?
RubiSRT
Iowa
I supplied Don @pixeldecals with the vision and he did the rest. No, I had the window tint place do it for me. I don’t have the patience to do it. I do a bit more orange accent somewhere on the rear or back side.
Anyone have any ideas?
MacombRoger
Roger
SE Michigan
2018 JLUR Ocean Blue
Solution Architect
Well I did some of this a while back and other of it this past week. These are all "First world problems", but you know got to keep busy with mods.
I have had this kit from JK Innovations (looks like they have rebranded the company) for a couple years now. https://innovativeatproducts.com/sh...ith-arb-twin-compressor-ckmta12-package-deal/ I love it. I use for both Air up and air down. It can do 4 tires from 12 psi to 40 psi (I have the blow-off set for 40, then bleed the tires back down to 37) in just a few minutes.
Last year I switched the valve stem quick connects that ship with it to Haltec clip on ones (https://www.amazon.com/gp/product/B01938M8MW). These are my favorite, I use them everywhere. Very secure, and one handed operation. I think this product even ships with the JK kit now by default. So that was last year.
Jeep Wrangler JL What did you do TO your Jeep JL today? 1615225644322
Now this weekend was to solve me having extra steps. So to use this system, the air compressor hosing is open at the mount on each front seat rail. So after I pull out the hose kit, I have to connect it the passenger side seat, but not to the tires as they will drop air from the open port on driver side. So after hooking up passenger side to seat, then I go around to driver side, connect hose to seat, then to driver side tires. Then back to passenger side to connect those tires. Then back to driver side to release the air. Its like a little dance.
Jeep Wrangler JL What did you do TO your Jeep JL today? 1615225687745
So this weekend I added valves under each seat that I normally keep closed. I can now hook up passenger side, open valve. the do driver side, and open valve, and go right into dropping air. I told you, real 1st world problems. :)
Driver Side:
Jeep Wrangler JL What did you do TO your Jeep JL today? 1615225719192
Passenger Side:
Jeep Wrangler JL What did you do TO your Jeep JL today? 1615225742334
But then I got creative. I help others after wheeling put air in their tires, or sometimes I will have just one tire report low (mud/sand in rim is a constant battle). The JK kit forces you to do 2 tires at once, unless you start reconnecting the parts, and even then, the tire gauge is at my seat. And the blow-off is more unreliable when not connected to all 4 tires (not sure why). So I created a new hose. All very simple. At end of the line I connected in a Harbor Freight air gauge, and of course I added my Haltec chuck. So now I can simply add air to 1 tire on my Jeep or on a friends vehicle.
Jeep Wrangler JL What did you do TO your Jeep JL today? 1615225795299
And one more project (Not specifically for the Jeep). I have an air compressor at home, not sure I will use it to fill tires anymore, but I also created a custom air gauge to use that quick connects to air line, and has a valve, gauge, and 3' lead to a Haltec connector. That way I can fill a tire without having to bend over. Yeah, I might just be lazy. :)
Jeep Wrangler JL What did you do TO your Jeep JL today? 1615225855938
Thx1158
RWW
2021 JL Rubicon 2020 Land Rover Discovery
Retired USMC
I checked on the status of my order and purchased another part for the part pile...This time a Jtops sunshade. Jeep is scheduled to ship 3/13. For you Militay guys/First responders..Jtops offers a discount if you call them.
m3lover1
Ricky
Bay Area, CA
2019 Sting Gray JLUR, 2007 Yamaha R6
Installed Road Armor's fenders. But after I pulled off one of the rears, I realized they never sent me the rears! So now she's a frankenstein with mismatching front and rear fenders!
Road Armor is sending the rears shortly. Their customer service is superb. The product itself is amazing. Looks great, powdercoat is very good, and fitment is perfect.
Michael N
San Jose, Ca
2019 Jeep JLU Sport
Installed the Stinger 10” Jeep radio to replace the factory 5” radio. Huge screen and truly plug and play iIt did take several hours to install as stuffing all the wires in the dash was the hardest part.
FrostySerb
New Jersey
2021 JLUR/2017 Ram 2500 Mega-Cab LongHorn Cummins
Cruised the loaner
Dealership drove out the loaner / what a loaner
2021 rubicon
Dotta Chrysler Jeep sent a driver out with this and picked up ours to address the CEL. Thought that was pretty awesome considering I live 55 miles away from them ...
Multiple places..
Cruised the loaner
2021 rubicon
@FrostySerb
Considering that same dealer frucked you in the arse and used no K-Y jelly... well, that is the least that they should do.... Was them that knowingly, sent you on your way at Sales time with a JL that had who knows what wrong with it... CEL....
