Glamisfan
SoCal, 30 minutes from Glamis
2020 Sting-Gray JLUR
I made a rear license plate bracket that bolts on to the spare tire relocation mount. I like the look a lot more then having it in the spare tire. I got the idea from one of the members here. He bolted the license plate light to the tailgate. I just took it one step further and figured out a way to do it without making any permanent mods on the jeep.
Jeep Wrangler JL What did you do TO your Jeep JL today? AC388102-46D9-49C0-BB5F-1DFFEDB0BCF3
Jeep Wrangler JL What did you do TO your Jeep JL today? 223EEDBB-0C6A-4571-815F-C4C04FBE92C3
Jeep Wrangler JL What did you do TO your Jeep JL today? 17063B6F-AF12-4523-A072-602AA5FC6244
Jeep Wrangler JL What did you do TO your Jeep JL today? 417E36D8-DF8B-47D2-9C63-ABEEFDDEE6B6
rkerr188
2019 2.0L Jeep JLUR
Wow, sounds good! How was the Mishimoto catch can install? I’ve been thinking about one ...
Stormin’ Moorman
Georgia
19 JLUR, 20 JLUR, 21 JL, 21 GCL, 89 YJ, 04 LJ
Forester
Turn off the lights yo, And I’ll glow.
your move @Headbarcode
dance, rush the speakers that boom
I'm killing your brain like a poisonous mushroom
I didn't even have to google it...that's so sad and embarrassing
DaddyEngineer
Tomball Texas
2019 JLU Rubicon
Jeep Wrangler JL What did you do TO your Jeep JL today? giphy
Any more details? I think this looks great and would like to copy it when I get a new rear bumper.
Glamisfan
I used some 2” x 1/8” steel strap and some 1” square tube, along with a $10 license plate mount. Welded the square to the flat, drilled holes where it bolts up to the spare tire mount and I drilled and tapped holes for the license plate bracket to bolt to the strap. I tried it at first without the square tubing and it was not rigid enough. I also already had the license plate wiring rerouted through the tailgate for the spare tire when I had on there, so I just cut that one off and extended the wiring to the new mount.
CarbonSteel
2023 Ford Bronco Wildtrak
Installed a Tazer Mini and set the tire size and TPMS pressure. Getting the connectors out of the OEM box required a major in contortionism. The YT videos made it seem like they would practically fall out.
Shoutout to @Halstem1 for the great deal on it.
cosine
NY
2019 Wrangler Sport jl
Gone Postal
I added finished the install of the Rugged Ridge Snorkel. I put the tall snorkel on for the day, but will most likely just run it in the low mount installed for normal driving and put the tall mount on for extended trips.
Jeep Wrangler JL What did you do TO your Jeep JL today? tempImageS0aIGF
I painted the intake mesh for the upper and lower intakes red. I just though it needed all the black to be broke up some. I also ran the air box drain to the the front bumper with a valve so it would be convenient if I needed to drain the air box.
I think this may improve my mileage. This really opened up the amount of air that get pushed to the air box. The stock air intake tube is maybe an inch to an inch and a half in diameter. It is maybe a quarter of the size of the intake tube for the snorkel.
looks great. i like the fact thats theres no holes to drill into the body. was the install pretty easy and straight forward.
Glamisfan
I got my Raptor-esque lights mounted in the grill. They’re the same lights as my turn signals, I shaved them down so they press into the grill. For now I just have them wired up to the marker lights. The first two pics are of the three lights and then with the hazards flashing. The rest are other designs that I played around with for a few minutes.
