JJSix
Tucson AZ
2020 JLUR, 2016 Dodge Caravan
Military
Did the CavFab rear tire carrier install today. Overall I'm very pleased with the look and the function as it is pretty much perfectly level on the swing out and return, no grinding/hitting/dinging or anything like that when closing back up and doesn't seem to move in the slightest up or down when closing.
Install took me about 4 hours total, 3 hours of actual work time. I had to run to AutoZone 2x, once to get a T55 bit I didn't have and another to get more heat-shrink wire connectors and a pigtail. The kit comes with a mount for the 3rd brake light and the camera but I wanted to run tag lights as well. The best solution for me was to run the Rugged Ridge bolt replacement ones. To do this I put in a pigtail so they could be disconnected not only right up near the light itself, which works but is hard to get to, but also from the inside of the tailgate. This makes it just a bit easier for me when removing the tire from the carrier (the camera and the brake light can be disconnected at the source.
Jeep Wrangler JL What did you do TO your Jeep JL today? 131106098_468036351275007_1091872479462810596_n
Jeep Wrangler JL What did you do TO your Jeep JL today? 130708102_3889918147694036_2538031347057276042_n
Jeep Wrangler JL What did you do TO your Jeep JL today? 130754254_3851751278202270_8424110899600829150_n
TP1
2021 JLU
Got the new tires on! Bit of an issue with the spare as it looks like I will need to get or make a relocation bracket. Need to lift the spare up about 1/2”. Had to drop the air pressure down to 20 psi to close the tailgate.
Jeep Wrangler JL What did you do TO your Jeep JL today? 131381986_447986926195303_8158466562098879277_n_LI (2)
What size tires did you go with?
blnewt
New Mexico
Just ask @cosine he knows!
C_Rat
Southwest
2021 JL Sport
295/70 R18 Nitto Ridge Grapplers. Measure 34.3” in diameter and 11.8” wide
Jeep looks great! Any rubbing or other fitment issues with that size tire?
Running any lift at all?
I'm getting the same tires but deciding between 285/75/17 or 285/70/17
Heimkehr
Pennsylvania
2021 JLU 2.0T
I added a piece of silver trim to the front cupholders. It just seemed to be a missing element from the factory...even on the Sport. It adds the finishing touch.
(I do know that the parking brake trim is loose.)
Jeep Wrangler JL What did you do TO your Jeep JL today? Cupholder trim a
Jeep Wrangler JL What did you do TO your Jeep JL today? Cupholder trim b
Renegade Wrangler
Gasan
Atlanta, GA
Wrangler JL Rubicon
Spice Man
I would love to get a link for that, it really looks nice and fitting
Heimkehr
Pennsylvania
2021 JLU 2.0T
I should have included the link in the original. :blush:
Click.
The reviews are correct that the provided tape will not secure the trim to the cupholder. I scientifically applied a series of very small superglue droplets around the perimeter, on the tape's now-exposed adhesive side, and held the trim in place for 1 minute. A perfect and secure fit now.
Renegade Wrangler
Gasan
Atlanta, GA
Wrangler JL Rubicon
Spice Man
Click.
The reviews are correct that the provided tape will not secure the trim to the cupholder. I scientifically applied a series of small superglue droplets around the perimeter, on the tape's now-exposed adhesive side, and held the trim in place for 1 minute. A perfect and secure fit now.
:fist bump:
MyDaughters20JL
WA
20 JL Sport S
306overland
Saskatchewan
1994 YJ, 2020 JLU Sahara Altitude(sold), 2023 JLUR
No rubbing at all and they line up perfectly with the fender. No lift yet but I was planning on 2.5”. I will run it as is for a couple months and then decide but I am even thinking a 1.5” spacer lift might be in the works!
MandKM
‘73 CJ5, ‘19 2-door JL Rubicon
Earlier this week I installed a 10” Baja Design wide driving amber light bar. I’m using the Homelink garage door opener to operate the lights via a RF relay.
Jeep Wrangler JL What did you do TO your Jeep JL today? 2505714F-0FEC-46D7-AF04-61FF907E1ACE
Jeep Wrangler JL What did you do TO your Jeep JL today? 994C3E3E-C20D-4E02-B71C-093B240D5576
Jeep Wrangler JL What did you do TO your Jeep JL today? 265D1351-9E6E-411E-9299-DE37FFB3A047
