JLURUBI
Idaho
2021 JLU Rubicon Diesel
Missing body mount bolt in my new Rubicon
Drivers side front. Found it while getting ready to install rock sliders......and no I didn’t break it trying to remove
Jeep Wrangler JL What did you do TO your Jeep JL today? D099243C-3C92-482F-99B2-AACA7E5D511C
The local dealers didn’t know how to fix it and had no experience with the issue. I had them order the bolt and bottom half of the mount.
It wasn’t that bad to fix. Built a jig to keep the drill centered and tried an extractor and heat, but no way it was coming out. Removed the rest of the bolt with a Dremel and a carbide burr because the extractor chewed the bolt out off center. Couldn’t save the original threads so I drilled and tapped it to 5/8. Grabbed a grade 8 bolt drilled and tapped in the lathe, and put a small shoulder on it. Then installed with some loctite. Better than new! Maybe this will help someone else
RubiGrey
Calgary
2021 Jeep Wrangler JLUR
Got Stek paint protection film on 90% of the Jeep.
I’m planning on getting the Mopar lift installed in the next couple of week. I love how aggressive it looks.
will I lose the aggressive look with the lift?
Jeep Wrangler JL What did you do TO your Jeep JL today? 4C62DB9F-36B0-454E-8EAC-7D3486501601
Jeep Wrangler JL What did you do TO your Jeep JL today? 1F44FFF4-D556-4669-8F0B-E82C18B09012
ODDs
Phoenix
2019 Hella Yella Sahara
Got Stek paint protection film bar all on 90% of the Jeep.
It looks pretty damn good without the lift. Very nice!
melendez69
Marc
Waxhaw NC
2018 3.6 JLR / 2013 911 / 2013 E92 M3
...huh?
any noticeable difference in steering feel?
I took it for a test drive around the block and it feels a little bit looser...I kinda like it. I'll drive around with it for a while to get a better feel for it, but I do like the Fox a little better... I just didn't like it hanging low.
JayJay
Johnny
North Georgia
'20 JLR
Valvoline 75w90 in the rear with mopar friction modifier. 75w140 in the front they each take about a quart and a half
The weights seem backwards to me.
JLTruman
Las Vegas
2019 wrangler jlus bright white
I read some of the diff fluid threads and maybe I'm wrong but that's what others were using. I looked up the manual and I used the wrong fluid for the front
Jeep Wrangler JL What did you do TO your Jeep JL today? Screenshot_20201130-181442_Drive
I read the manual before I ordered the oil but I still did it wrong.... oops
GtX
Illinois
2020 JLUR 3.0D
Working for the man.
Are the rock sliders just as strong with the windows down, as they are when they're up?
Sure are. And more importantly my old ass can use them as a step!
Rangemaster
Nevada
2020 JL Rubicon Diesel
Business Owner
Worked on the JLUD installing the the LoD destroyers, and had a major issue to overcome. There is a welded pin in the rear body mount on the diesel that is not on the regular JL. Made for a long afternoon with a mini cutting wheel to allow this to slide up in the mount.
Jeep Wrangler JL What did you do TO your Jeep JL today? 1256A5B4-5FD5-461E-9587-7F2A3876B055
Jo's Jeep
Anywhere but here
None
Finally made it official and named my JL "Leviathan". Commemorated this by installing some @pixeldecals lettering on the hood. Reflective dark gray with a lighter gray outline. Super smooth install, just got take your time (only 1 slight mishap on my part as one of the letters got folded up on itself a little bit. Oh well, no big deal - I'll see if I keep it as-is or order another one to replace it).
Normal:
Reflecting the light from the camera's flash:
Wet shavers are going to think you're advertising Barrister and Mann's shave soap of the same name... It's always sold out.
Jeep Wrangler JL What did you do TO your Jeep JL today? barrister-and-mann-shaving-soap-leviathan-2_6b39121d-6123-4db9-8809-951bb3b6587c_473x608
Heimkehr
Pennsylvania
2021 JLU 2.0T
Perhaps the vendor, and/or manufacturer, might appreciate being made aware of how the installation is compromised on the JLUDs. Just a thought.
Well done on working through it. :like:
acenines3
NJ
2018 Jeep Wrangler Sport JL
My dash speakers came in today but the Metra speaker wire adapter is b/o. Oh well I guess I'll have to stare at the box.
Jeep Wrangler JL What did you do TO your Jeep JL today? tempImageCIA1EP
Heimkehr
Pennsylvania
2021 JLU 2.0T
Those exact speakers are due here today or tomorrow. :) My wiring adapters are on backorder, also. I ordered from Crutchfield via their Cyber Monday promotion.
I'm hoping for a cleaner midrange, if nothing else.
I just used a fair bit of toner printing the 17 page Master Sheet document, too. Crutchfield used to provide a hardcopy document (I've been buying from them since the 80s). They will still do so on request, but this isn't advertised. The customer has to know to ask for it. Just an FYI.
