oceanblue2019
Yeah they are black painted. Mine are flaking already too.I think ,too. But dealer told me this bolt is right one, it look like black painted.
Might be a dumb question... but I have done my own oil changes, and I also changed out both front and rear diff oil. I want to change out the t-case fluid but there seem to be much less (if any) DIY posts or videos. It seems simple enough, but can you share a bit more info please?Went under my JLUR today and changed out the transfer case fluid. I’ve only got around 9,000 miles on the clock but mainly because I was looking for an excuse to wrench in the garage I decided this would be an great time to complete this task.
I ended up going with Redline C+ATF fluid but only because I was given a couple of bottles by a friend.
2 quarts of ATF+4 fluid meeting the Chrysler MS-9602 standard is all you’ll need fluid wise. Valvoline, Pennzoil, MoPar, and other manufacturers offer a wide selection of great choices at much cheaper prices than the Redline.
If you do go with Redline, two things - first, it doesn’t carry the official MS-9602 certification (important to some folks; apparently due to business reasons as opposed to quality). Secondly, a standard quart size hand pump (essential for dispensing the fluid neatly into the fill port) won’t screw securely to the Redline quart size bottles.
I kinda prioritize a mess-free experience (at the expense of time) and so I ended up funneling the Redline fluid into empty standard size quart bottles. It was an extra step but it made the filling process completely mess and drama free.
You’ll also need a 10mm hex bit, a torque wrench, a drain pan and if you have a JLUR you’ll want to definitely consider acquiring these two things for the job:
1) Flexible fluid funnel:
2) 12 inch extension bar for your wrench
The skid plate makes emptying the fluid a chore to do without spilling it. One option is to remove the skid plate altogether or perhaps maybe as few as a couple of bolts on it to “swing” it out of the way (or so I’ve read).
Another approach (the one I chose) is to use a flexible/malleable funnel which allows you to position the funnel between the skid plate and the bottom of the transfer case. Within a few seconds, the funnel can be easily manipulated through a slot in the skid plate and contoured perfectly into a pre-positioned drain pan on the ground.
The result for me was not a drop of fluid was spilled and not a single bolt was turned on the skid plate when draining the old fluid.
The 12” extension bar is to make it easier to use the torque wrench (it can be tight fit under there) to loosen/reapply the drain and fill bolts to factory spec. The length of the factory skid plate can make getting a good turn on the wrench a major accomplishment and a 12” extension bar was just what the doctor ordered.
Can you provide details on the rack model?Perfect day for a wash.. and put the rack back on.
What side steps? They’re awesome, I’m looking at the ace engineering so I can still keep my stock rubi rails but these look very clean..Finally added a Sunrider just in time for another wheeling trip in Ouray this weekend!
No issues with the new steering box and the Synergy Sector Shaft brace? I have the brace but never got around to installing it. Now I am waiting for the new steering box. Is the steering a lot better now?
After TSB. I put back synergy track bar brace and teraflex track bar.
I guess better than before, I put it back as a some kind of insurance.No issues with the new steering box and the Synergy Sector Shaft brace? I have the brace but never got around to installing it. Now I am waiting for the new steering box. Is the steering a lot better now?
I sold mine.I put it up for sale today.....
How hard of a process was that? Looks good. I'm interested in doing the same thing.Stub-ified the front Mopar bumper.
why? well, why not?
Those look great any details on the process? Materials used, etc?Made and installed my own (with some help) custom headliners yesterday afternoon.
