SpookyXJ
Ed
TX
2019 Sport S 2 door auto
Looks good! How do these look from the standpoint of collecting rocks Where the flairs meet the body? Do they look better than the stock Rubicon’s? Thanks.
Not sure about the Rubicon flares but its much better than the Sport flares were. The rear set its a total non issue it should not collect any pebbles. The fronts there is still a bit of a trench on the top of the flare but its much less pronounced and just looking at it any gravel that collects should spray out with a water hose and not get stuck like my Sport flares did.
zeebo56
Zee
los angeles
2020 jeep wrangler unlimited sport
A fellow JL owner who does 3d printing and wanted to do something for the Jeep community. He charges little more than what the material, his time, and shipping costs. I also got his obd2 port cover. I don't know how to do links, but he's on Etsy, his name is Joe, and his company name is ClickOnPC.
Cheaper than the eBay seller and seems worth it
pdx_jeep
Portland, OR
2020 Wrangler Rubicon 2-dr
Installed the first speakers that arrived - front corners. Kicker KSC350's. Quick install, made a lot more than $70 difference in my opinion...worth the $
funny, I ordered the same speakers from crutchfield and was supposed to get them today but the shipment was delayed. Glad to hear they sound great.
zeebo56
Zee
los angeles
And, installed the @ORACLElights Oculus Bi-LED Headlights... Quick one night review... I've never seen a line so crisp as the line between light and dark with low beams on. AND, they required no adjustment. They were both spot on out of the box.
Looks sweet, are those the RGB ones?
aphillips76
Aaron
Denver
2018 JL 2 Door
No. Honestly, I wasn’t a fan of how the RGB worked. I thought about doing a whole rgb setup with the fogs, rock and interior lights on Aux Switches. The thought being that I would just use the aux switch for turning them on and off assuming they remembered the last color they were on. The reality is that to turn them on, you must use the remote. I don’t want to have to have a remote all the time...
Nikko2020
Chicago
'20 JLUR, '21 4R TRDP, '21 Supra, '13 LR4, '72 442
Any issues with the wiring? I thought I remembered some issues with the wiring being opposite of what it should be in the directions?
uudog
Northern VA
Jeep Wrangler JLU Rubicon
I wrapped mine around the front seatbelt so it’s kind of pulled forward and sits in the crease between the rear ac vents and front armrest. Not that it would, but i didn’t want it blocking any airflow for the rear ac.
Thanks for the tip. This seems to work better (for me) than hooking it under the seats. I sits better on top of the vents vs. partially covering them.
Wicked Weasel
Bob
New Jersey
2018 Rubicon JL - Build date 06/18
ordered the parts and scheduled the work for my lift (assuming this qualifies as something I did today lol)
  • 2.5 Inch X Factor "No Limits" System
  • FOX 2.0 PERFORMANCE SERIES IFP SHOCK FRONT, 2-3IN LIFT
  • FOX PERFORMANCE SERIES 2.0 IFP SHOCK REAR, 2-3IN LIFT
  • Steer Smarts bottom mount drag link
  • Steer Smarts RUBICON tie rod assy
  • Steer smarts stabilizer clamp 1 5/8
  • Steer Smarts stabilizer
  • Front 1-4" Bump Stops
  • Rear 1-4" Bump Stops
jlewissystem
J
STL
2019 JLUR MANUAL Mojito!
Crutchfield must be happy as I ordered them this week too. Mine will come in tomorrow.
You guys that are replacing your OEM speakers and using the Metra adapters, check the polarity of the wires. I had to switch all of the wires in all of my Metras. My thread has references, if you dont want to search.
Goblue
Darran
JLU/OB
FF/PM
Finally installed spicer 4.88 gears and im on the break in process
Jeep Wrangler JL What did you do TO your Jeep JL today? BD138ABF-98AA-4413-B74C-D32C93A7EB0F
Looking good, question I was thinking of getting and Evo lift and 37s is re gearing something that I will have to do and also the drive shaft
davidsrosser
Frisco, TX 75035, US
2020 JLU Willys
Yes, I called Crutchfield and bitched at them for their weak instructions that did not cover these particular speakers.
For these, you do have to use the 3 wire crossovers that are provided by kicker in the box, then splice positive (white) and negative (black) to the harness adapter provided by Crutchfield.
jlgolfcart
Southeast Michigan
Bikini JLRU
I just bought the 1UP Equid -D Double bike rack. Does anyone know what length hitch extension I need? I will have a 35x12.50 tire on the back.
