Kenny
Did you paint them on or take them off? What did you paint them with? Looks good IMHOSome people like the contrast of red and some people don't. I might paint my other set Punk'n.
3 1/2 for me. Since I was upgrading most of the parts down there, why not. Wanted the new setup to be durable and strong enough to handle day-to-day demands.Why Drag Links? How high did you lift? I ask because I’m advised until you go 4” plus, it serves little purpose. However, I would value correction.
How wide is the opening of the cell phone holder? I have a wallet/cell phone cover and it's about 3/4 inch thick, will it fit into that holder?What winch cover is that? Is it hard to get on? Doesn't look like there is a lot of space there, but I really like the look. I have the same winch. Love the Gibson's. I have them on both sides.
What brake lines are on that Jt?Couple of days ago did something very easy, put on some amber covers.
Yesterday installed the Decked storage system on my uncle's JT. Probably one of my favorite mod, even though its not even my own car.
I also fixed my wiring for my ARB twin compressor, no more popping both of my 40a fuses after airing up 8 tires. Turns out it was the red positive battery wire I used originally to extend the wiring. Bought new wiring and fixed the problem.
Today did some water testing on the Decked, and everything stayed dry after spraying it with water hose.
Then also installed Metalcloak rear diff cover and front axle disconnect skid on my uncle's JT.
OEM.What brake lines are on that Jt?
Cool deal. I wound up going with a different tire though.I just swapped them out with 32,000 miles on them. Hope this helps
I have an iPhone and it fits good leaving room to insert and remove phone without any trouble. At 3/4 inch thick would definitely pushing it and probably will not fit. Try calling them they might be able to accommodate your needs. Best place I found for phone, I do not like anything mounted in my face or on the dash anywhere. I also ran the usb cable from inside the armrest along the underside of the center console.How wide is the opening of the cell phone holder? I have a wallet/cell phone cover and it's about 3/4 inch thick, will it fit into that holder?
Save some mods for the rest of us! lolAlso installed the wire harness for the 12volt solutions remote start system. Did the stage 1 programming with the module, and will have to send it back to them for stage 2 programming before finishing the install.
