wv18jl
WV
2018 JL
rustyshakelford
Brett
Navasota, TX
2019 JLUR-8 speed 2020 F-350
Are these available?
Will order now if so.
Not yet. Will be available around February. Iā€™d contact roam and see if you can get on a pre order list. If they are anything like the rest of them products, they will be going fast
Brett
MSchir1
Michael
Cherry Hill, NJ
Wrangler JL Sport
Those look great. Iā€™m trying to decide between those and the D1 model. Did you have any trouble with the body bolts?
Mounting the brackets to the body was no big deal but the bolts connecting the nut plate inside the step to the mount was a real PITA. I got really good advise from @vhfan5150 to keep everything loose and half lined up. The issue is the hex bolts they provided only allow an open ended wrench to tighten which you can only turn a 1/4 turn at a time x12 bolts. If you have patience (lots and lots of patience) the steps are great, just enough step for a solid footing without sticking out to far.
IronScott
NW Arkansas
Cool! Thanks for the advice and notes.
TroyBoy
Troy
Vancouver Island, Canada
Installed my artec license plate relocation bracket. Now if my smittybilt xrc rear bumper would arrive.
Moto_21
Erik
Corona
2018 JLU Sport
Maintenance
Installed 1.75 spidertrax wheel spacers, Rubicon shocks and springs, and a TeraFlex 1.5 performance spacer kit. Waiting on stock tires to wear out.......
Looks good man!
AggieJeepGuy
NW AR
2018 JLUR (replaced 2007 JKUR); 2016 Durango Brass Monkey edition; 2011 Expedition; 2002 Trans Am WS6 6spd
Got the new wheels installed today (17x9 Method Standards). The extra rim width really changed the look of the tires ... more squared off and mall crawlerish They looked good on the stock rims but I think just ok on the new ones. Thinking I will end up switching from st maxx to stt pro before it's over. The backspacing on the wheels added about 2in of added width (tire outside the fenders .. before and after below) on each side as well. Used tpms recommended here but so far only 1 of 4 has registered.
Martindfletcher
Martin
San Diego
Ducati 1299s, 2018 JLUR
This is more what did you to your jeep the last 2 weekends. Itā€™s almost done. I soldered almost every connection (accept the reverse light tap in.)
1) rerouted arb air compressor wires inside the jeep through the hole near brake vacuum reservoir. Still need to cut and insert a grommet
2) installed ham radio. Ground strap for quad band antenna
3) installed hard wire for arb fridge
4) LOD Destroyer with rigid back up defused lights. Butchered up a rigid wiring harness with relay. I may add an opinion to power them with Aux switches, but figured if I really need light back there I am in reverse or doing something behind the jeep.
