THAW
Foster
OR
23 JL4DrRubicon
Installed a non-camera middle grille mesh, removed 2 washer hose elbow fittings, extended the washer tube, and used some shock cord to make my OE front camera compatible with my Bolt hood lock.
Lock access mode:
Jeep Wrangler JL What did you do TO your Jeep JL today? 1000002418
TrailCam mode:
Jeep Wrangler JL What did you do TO your Jeep JL today? 1000002415
ORACLE Terry
Peak Sponsor (Level 2)
Terry
New Orleans, LA
Gladiator, Wrangler JL, Bronco, RAM TRX
So far this week I’ve added a pair of Oracle fog lights with RGB leds on my wife’s Sahara, rough county tailgate table to my Rubicon and a Rox off-road flag holder also to my jeep.
Hoping to pickup a new front bumper if I can get my DJ5 mail jeep to sell sometime soon.
The fogs and the tailgate table look great!!! I just my RSE Tailgate Table this week. I can't wait to install it.
SadRobot
Los Angeles
2019 JL 2dr Sport
Got my driver side AAL Highline working. The connector is still stuck on but I sprayed some contact cleaner into it (not ideal as I wanted to get the connector off first but just couldn't). It's working for now so I guess I'll see how it handles driving around.
I also just hit 75k miles so did an oil change. This time I 100% reset the oil life since I seem to have forgotten last time.
Jeep Wrangler JL What did you do TO your Jeep JL today? IMG_2715 2
Fuel Fire Desire
Michigan
2018 JLU Sport S, 2020 JT Sport
Installed Fox ATS steering stabilizer to handle the steering wheel shake when driving on the uneven and pot holed roads around my area. It became more pronounced after installing the 35s and wheel spacers. Handles real nice now and really like the adjustability.
I noticed a small increase in stability when I did my Fox stabilizer, though the monumental change I had came from bringing the castor from 3.8° (stock) to 6.0° with LCAs. Wandering went away, steering firmness went up, return to center was more positive, and wheel shake over bumps went away. I’m on 35’s too.
BigMaCro
Moved to Iowa from Alaska
www.youtube.com
2021 JLU 4xe Rubicon
Carhauler
Installed a couple interior items from Azuto Japan featured on dirt road cred.
First are rubber cupholder coasters that should have been factory
Jeep Wrangler JL What did you do TO your Jeep JL today? 1000003698
Next is the rear window "trench" that fills the gap between glass and hardtop so water doesn't drip down onto you when the glass is open.
Jeep Wrangler JL What did you do TO your Jeep JL today? 1000003695
Heimkehr
Pennsylvania
2021 JLU 2.0T
That brand is overpriced, IMO, but I have to give them fair credit: almost everything they sell looks absolutely factory-correct for our Jeeps. Those cupholder inserts certainly qualify here.
I've the map light in my JLU, and to date no one has correctly guessed that it's an aftermarket item. Yes, at a C-note, it's pricey, but it was also gifted to me. :)
JJ_WA
JJ
Puget Sound, WA state
2002 Dakota, 2017 Cherokee, 2023 Willys XR
Higher Education
I aired up my tires after getting fed up with being greeted with the "tire pressure low" screen over the last few weeks. The psi's dipped below 30 during a cold snap in mid January. Apparently going under that threshold triggers TPMS to go into annoy mode ?
This could also go under the "things I just found out about my Jeep" or whatever that thread is called, because I didn't know that TPMS won't clear the message until you get the psi back to 37 or higher. Initially, I filled the tires to 32-33 and was greeted with the message again, then to 35...same thing until the tires warmed up to get the psi's back to 37...gah!!! ?
The message I received on the dash was to air up to 37 lbs. I finally got around to it. After hitting 37 I had to drive a few hundred yards before the TPMS updated.
Grateful1
Grateful
Guntersville, AL
2018 JLU Sahara 1998 TJ Sport 2011 Extreme Camper
HR Manager
Sounds like something I would do. Those Highline fenders look tough. Got a picture with all the front lights turned on?
Grateful1
Grateful
Guntersville, AL
HR Manager
I like Azuto stuff as well. I am ordering the rear glass water trench and the rear glass defroster corners. I like the cup holder rubber. Before I seen those I order a set off eBay. I will take pictures this weekend. I tried to order the turn signal extender but it is unavailable. I have other mods I have been waiting to add but the weather in North alabama will no cooperate.
Grateful1
Grateful
Guntersville, AL
HR Manager
It's lunch break time for my rubi axle swap day
Dang. What are you going to 1 Tons? What are you doing with your Rubi axels?
