NeilP
Neil
South Dakota
2024 Jeep Wrangler Sahara Unlimited
RETIRED!
I opened up the tailgate and rear window to check out the dealers "repair" for the rear window defroster. I discovered that the repair lasted less than a day. Now I gotta go get my $$ back!
Mx5red
Paul
San Diego
2020 JTR, 2020 JLUR
I added a little "class" to the Jeep today. It is now sporting a new black Ford Bronco antenna. The Ford Bronco antenna has a rubber coating and is a few inches shorter than the original. What do you think, keep it or put the stock one back on?
It looks great, but your antenna cost you $60k? There are cheaper options
Geronimo
Boltz
2013 JKU , 2018 JLUR, 2023 JLR all DDs
washed cow poop off to prepare to drop off for 488s on Tuesday. Didn't think he would like cow crap as much as I do. Its great on my tomato plants
NeilP
Neil
South Dakota
RETIRED!
Signing Spock
Kenny
Belgium (originally, Sn Antonio, TX)
24 JT Willys
USAF Cyber Security
I think you “might” have the shelf upside down…unless you purposely intended to use it that way
You can flip it either way, but the instructions have it this way so I said ?‍♂ and did the same. This way works well because we can stack things higher I’d think. But if you have to worry about flooding then I would’ve flipped it for sure. I’m on a hill though so I was good with this way.
Rubi6mt
Nj
2021 JLUR 6mt
Not exactly TO my Jeep but more FOR my Jeep.
Since I've installed the 37s and the lift, I can't clear my garage anymore by a few inches.
Jeep Wrangler JL What did you do TO your Jeep JL today? 20230304_134836
So I bought the RollnJack and put it together for when I swap out the soft top in about a month. Took about 30 minutes
Jeep Wrangler JL What did you do TO your Jeep JL today? 20230319_172458
Jeep Wrangler JL What did you do TO your Jeep JL today? 20230319_172721
Jeep Wrangler JL What did you do TO your Jeep JL today? 20230319_174435
Test fitting in the Jeep. Fits great.
Jeep Wrangler JL What did you do TO your Jeep JL today? 20230319_175143
JasonInDLH
Jason
MN
21 JLUR, 15 Yukon Denali
I’d Rather Talk Jeep’s!
Dropped it off at Ken’s Kar Kare to have a regear to 4.56 and f/r Truetracs installed. Should be done Weds or Thurs.
How much are they charging you for the gear change?
Rival 4x4
Houston, TX
www.rival4x4usa.com
JL Sport Stingray, JL Rubicon Firecracker Red
Installed the @Rival 4x4 Aluminum Muffler Skid. Went on super easy: loosen 4 sway bar bracket bolts, slip mounting brackets between sway bar brackets and frame, re-tighten using factory hardware. Passenger rear attachment super simple with nut-insert; surrounding holes are large enough to easily get fingers in there to hold it down while you tighten. Driver side rear attachment was a little trickier, especially with the factory tow package. No access to hold down nut-insert so had to get creative. Used a magnet while inserting bolt up through frame hole - held in place long enough to get thread started, then everything tightened up fine. Super sturdy, looks great. Thank you Rival for a quality product (and keeping me from having to paint my muffler black ;)).
Love that black stylish look ?
Maverick909
Inland Empire
www.instagram.com
2018 JLU Sporticon, 1976 GMC K15, 67 Notchback Barracuda
Good luck. I’ve taken mine in once and did it twice myself. I gave up on the rear defroster. It just going hang there until I remove the wire completely
yokramer
North Carolina
'23 JLR, '13 Juke Nismo, '88 10th Anny RX7
Made a base plate for a diy goose gear style system. Took a while to find the clamping solution I had in my mind and made some clamps that are used to add grounding to pipes. Fred in the back is a huge fan, Wilma up front isnt quite sure yet.
Jeep Wrangler JL What did you do TO your Jeep JL today? fit
Jeep Wrangler JL What did you do TO your Jeep JL today? done
Jeep Wrangler JL What did you do TO your Jeep JL today? holddown
Jeep Wrangler JL What did you do TO your Jeep JL today? bracket
Jeep Wrangler JL What did you do TO your Jeep JL today? tether
Jeep Wrangler JL What did you do TO your Jeep JL today? Beagles
JasonInDLH
Jason
MN
Regear, new HD diff covers, and labor is $2900 including 6% tax.
Thanks! I’m considering changing as well and I can keep my shop honest.
Huntinwild88
Nathan
Alaska
2021 JLU Rubicon
Installed a .75° bushing on my driver side balljoint to correct my camber. Jeep deep doesn't pull to the right anymore!!
AdamG
Adam
SE Michigan
2019 JLSportS
Another shop quoted $2600 all in but without the covers so same same. I ultimately went with Ken’s because they listened and responded and I felt more comfortable with them. And @wibornz gives them a thumbs up enough to put a sticker on his Jeep and he’s certainly not easy on their work.
bem1
Blake
lantanapcguy.com
2018 JL, 2024 JL
