XJfanatic
Indianapolis
2020 JLU, 2020 JT, 1990 Mustang
Jeep took over the gym. Nice lol. Mods can give you a good workout anyway :like:
Jeep’s can be gyms. I remember carrying around front axles like they were nothing when I was wrenching every night. 12.5 years in the army doing army pt and now I can pick up a front axle then lay on couch for days. 😂😂
Heimkehr
Pennsylvania
2021 JLU 2.0T
I have at least 5 straws and couple other things in the abyss.
There's a grocery store loyalty card in the seat abyss of my Wrangler. Of course it had a time-limited 40 cent per gallon discount on it when it went missing; that's no small matter in the state with the nation's highest gasoline tax.
I had a new card issued, and started from scratch with the gas discounts.
XJfanatic
Indianapolis
Replaced the batteries. I started to get the start stop light sporadically this week. Apparently 20 months and 35k is too much for the AUX. It started to bulge some, took the opportunity to upgrade to the bigger main battery while I was in there. I went in through the top as I didn’t have any spare fender clips, it wasn’t too bad about 45 minutes.
Just a quick update since this battery replacement that I noticed today. Greatly reduced 2.0l cold sputter, trans is seeing 8th more, mileage increase and less turbo lag. Could be totally coincidental but nothing else changed. These things are known to cause all sorts of electrical issues when they go out. Maybe they start by lessening spark quality.
wibornz
Ted
lansing, Mi.
www.instagram.com
JL Unlimited Rubicon
After 5 days of camping in the UP of Michigan. My wife said this tote needs to be on a slide. So while she was at work, I headed to Menards and picked up a 24 in slide that would support 100 pounds and built the tote slide.
Jeep Wrangler JL What did you do TO your Jeep JL today? 1629807204629
Jeep Wrangler JL What did you do TO your Jeep JL today? 1629807229379
Total cost was about $85, and about two hours of time. I could have built it faster, but lacked some cool tools so I had to make due with what I had.
Suffolklou
Lou
Richland Wa
2020 JLUR
@VWillys
For use with the D Rings..... if you ever say carry gas cans, totes, well..... anything that you need to secure in the center rear of your JL..... consider 4 of these.... they can be found at Walmart in the Automotive section and they are very inexpensive.
These work great in conjunction with the size of the D in regard to the D Rings... Size of hooks and size of rope is great. Ratchet action a plus.... works well. Length of ropes is very good. Easy to deal with...
They also sell those at The Home Depot. I had 2 and one failed.
Now I use the niteize CamJam
Jeep Wrangler JL What did you do TO your Jeep JL today? tempsni
GATORB8
CLT NC
21 JLURe
Rhinebeck01
Multiple places..
GreatWhite13
jake
ohio
2020 jl sport s
Pick up needed new sway bar links from a forum member teraflex not to crazy about the holder mounting location but we will see
onto the rear control arms and then im done until the supercharger next month lol
GtX
Illinois
2020 JLUR 3.0D
Working for the man.
They also sell these at The Home Depot. I had 2 and one failed. Now I use the nite ize CamJam
Jeep Wrangler JL What did you do TO your Jeep JL today? 20210824_103349
These are great. I keep several of them in the rig sized for 550 cord.
LittleDog
New Jersey
2020 Sahara JLU
Finally installed a Femco click drain plug yesterday, after failing miserably last time.
FYI, the plug cap for the click drain is longer, and looks like it wants to get caught on things. I'd recommend the compact version instead, though you'd have to hit the pumpkin before getting to the oilpan anyway. I might change it.
FYI 2. When using the click drain plug, DO NOT push in while holding the green locking sleeve, or it will never engage:
Jeep Wrangler JL What did you do TO your Jeep JL today? 20210823_153427
Hold the barbed nozzle bit through the tubing instead:
Jeep Wrangler JL What did you do TO your Jeep JL today? 20210823_153434
FYI 3. Somehow, the Femco drainplug drained more oil than the empty plug hole. When I installed it, I clicked on the hose to test. This was after the oil had already stopped dripping for 5-10 minutes. When I clicked on the hose, and extra 1/6 of a cup or so came out. The plug-end and valve extending into the pan must have contacted a little puddle in there and pulled it out with capillary action.
