JasonInDLH
Jason
MN
21 JLUR, 15 Yukon Denali
I’d Rather Talk Jeep’s!
From0toJ
Midwest
2018 Firecracker Sahara (ordered 4/16/18, received 5/12/18), 2015 QX60, 2012 5.0, 2013 Prius V (hers)
Installed DV8 headlights, Q-tec pre-runner light kit, and put led bulbs in the fog lights, turn signals, drls and swapped side markers for led kit also. (Alright, I lied, that was a couple weekends ago...)
Very nice. Which D rings do you have?
Jaeth
Oklahoma
www.standardroofingok.com
2021 JLUR
I like them, I’ve had them a year or so. The one on the passenger kept falling off after a while, it’s just dbl side tape. So I made the commitment to keep it and put a couple small black screws in it. The drivers side also uses the tape but it hooks over the transfer case shifter, so it’s solid.
@jeeeeeeep @Roky
If you're having problems with sticky tape, we are using this one and it works great and don't need the tape. I know Mr Roky is always looking for something to change!
https://www.amazon.com/dp/B08XYPFHXK?ref=ppx_pop_mob_ap_share
Rhinebeck01
Multiple places..
I installed the final design offering of the DI Labs door lock cover with TREAD on my JL.....
Door lock covers keep the mud, sand, ice, water, horse chitt, etc. out of the door lock.
They also cover the shiny lock... and add black contrast to the side/rear of the JL.
For those interested.... DI Labs, today started selling their door lock covers... I'll say no more then that the quality, fit and look is exceptional. They are well worth the $ and look great..
Yes, as a tester of the product ..... I received a free, final design set of these with TREAD.. JUST KNOW, if they were not top notch I would not be posting positive like this/about the product offering...
https://mythreedom.com/products/jl-jt-key-hole-cap
Here is tread pattern:
Double click on this pic..
Jeep Wrangler JL What did you do TO your Jeep JL today? 20210816_122050
Dr. RGB
PA
No longer own a Jeep
Just added: Rampage Rock Rage Front Bumper, Quadratec 3/4" D-Ring Shackle Pair with Black D-ring Isolator Kit (Yellow Powder Coat), and some cheap Roadshock 3" LED Flood Lights (from Harbor Freight) with yellow Lamin-x film; all for a whopping $389 plus tax!
Jeep Wrangler JL What did you do TO your Jeep JL today? 65109538742__98ECA516-50AE-4418-A00B-13517C11C4D4
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
I installed some light duty D-rings, in the event that I decide to use a cargo net as frequently as I did in previous vehicles. Hardware wasn't provided, so after determining that M8x1.25 was the correct thread size & pitch, off to Ace Hdwe I went for some stainless fasteners. The washers came from shed stock.
Jeep Wrangler JL What did you do TO your Jeep JL today? 01C28EE8-3003-4CA0-8834-12C4D6DB486E
After I got home, I had to monitor Cat, lest 14 lbs. of paws & claws get him in trouble.
I noticed these tires while I was out. Who hasn't wanted a sweet set of Linglongs for their Wrangler? :LOL:
Well, I really like their Potstickers, so how bad can the tires be. ;)
Headbarcode
LI, New York
Thanks buddy! Just ordered 2 of the 3-piece sets. 1 Gladiator and 1 tread. I'll put the Gladiator on the drivers door and treads on the passenger side and tailgate, to avoid a rear facing soldier. The extra will come in handy in case one gets damaged or swiped off by a tree branch.
Thanks again!
Jeronimo44
Jake
Houston, TX
2024 JLU Rubicon X 4xe
how do you like your aluminum pedals? i was thinking of doing the same but wasn't sure if they hold up or become marred over time?
They’re fantastic! Worth the $100+ I spent on Amazon for them. They’re made of high quality aluminum, so I expect them to last quite a long time.
I installed the MOPAR ones on my GC Trailhawk and they held up fantastic.
Definitely recommend them. Install takes some muscle effort, but doesn’t take long. Helps to snazz up the cabin a bit, with the aluminum pedals matching the aluminum trim bits.
Plus, mud looks better on the aluminum than the standard rubber petals ;)
Heimkehr
Pennsylvania
2021 JLU 2.0T
Finished up my bracket for the ground bus bar.
Edit: I've had a few messages about making some brackets. IF there is enough interest, I could explore the option of making both brackets and putting together kits for sale.
I painted and installed the ground bus bar & bracket. Thanks to @spurly for the effort. I used a Honda touch up paint that is a closer match to Firecracker Red than the lighting in the photo suggests.
The label is my own addition. ;)
Jeep Wrangler JL What did you do TO your Jeep JL today? 20210821_103636
The bracket doesn't make contact with the pneumatic strut when the hood is closed. There's also fair clearance between the bracket and the factory grounding studs that are now underneath the bracket.
Dale's Jeep
Dale
Michigan
2018 Jeep JL 4door Rubicon
Retired U.S. Army 23 years
Installed my winch and took some measurements.
Jeep Wrangler JL What did you do TO your Jeep JL today? 20210821_094815
Jeep Wrangler JL What did you do TO your Jeep JL today? 20210821_094709
Jeep Wrangler JL What did you do TO your Jeep JL today? 20210821_094747
TKL223/3
Jon
Arkansas
Jeep JLU Rubicon
I finally found time to install my Reid knuckles and Steersmarts aluminum tie rod after having them sit in my garage for a few months. My Dynatrac ball joints got installed a couple of months ago with my truss and I have about 1500 miles on them. They’ve already started to feel loose.
Jeep Wrangler JL What did you do TO your Jeep JL today? 70ACA293-02C7-496A-8470-508F80B1B533
Jeep Wrangler JL What did you do TO your Jeep JL today? 743F55C1-2544-4FCB-A7C9-AD85C855E30B
Jeep Wrangler JL What did you do TO your Jeep JL today? 0DF6BFA9-544B-4816-B8AD-F0179EE4F6D0
Jeep Wrangler JL What did you do TO your Jeep JL today? A332F988-82A5-472C-AFD0-1538CDCC122D
lowmpg
Ryan
Kent Island, Maryland
2021 Rubicon
Finally a useful spot for the roof.
Jeep Wrangler JL What did you do TO your Jeep JL today? image0-1
