Do you know if that AVE bracket fits into a recessed fairlead area on a bumper with a recess such as the rugged ridge spartacus bumper?We got a wrench in for the light mounts with the winch on. Bumper wasn't mounted on the Jeep though so it might not be as easy.
I didn't use any of the ARB license plate mounts. Don't like the look (not low profile enough). I'm working with a friend to try and design a license plate mount that works off the two holes in the top front where they provide a mount for the solenoid box if you want to get it off the winch body. The AEV plate mount would work too but i'd have to get the fairlead off and I'm not certain I can do that without taking the bumper off (and that's NOT happening).
I did this....works great!...Finally got around building DIY door hangers, used Edie's write up on the "other" forum
I like that.... would like more info if you can....Swapped out the side mirror caps with the OEM export version to add signal lamps, and may have gotten a little carried away with the additional lighting. Hardware installed today, wiring still to be done. Baja S2 combos to light up the side blind spots will be controlled by aux3, 3/4” smoked amber led marker light will tie in with the fogs, and another 3/4” smoked white led underneath the mirror that will serve as a puddle light that comes on with the courtesy lights at unlock. Install not hard but involved a bit of cutting/shaping the caps and some of the mirror support structure with a Dremel. I’ll post again once I have a chance to run the wiring.
Didn’t “specifically “ do per say. But I did click some buttons on my phone & bought my first suspension lift ever
Can you say green house effect.Has anyone seen or heard anything about this New Top?
Transparent Hard Top Replacement Panels by ClearLidz (2018+ Wrangler JL, 2020+ Gladiator JT)
$1,349.00
CL300: ClearLidz Jeep JL/JT Panoramic Freedom Style Top. Whether your cruising on-road or wheeling on the trails in your Jeep Wrangler JL/JT, no better experience than having complete freedom.
The ClearLidz Jeep JL/JT Panoramic Freedom Style Top provides a topless feel without unwanted situations. ClearLidz is 100 percent made in the USA ensuring only the greatest of materials and craftsmanship. Creating a limitless feel with the 180-degree transparent construction. Worry-free freedom style top providing complete weather seal.
Our custom-formulated shatterproof polycarbonate top not only provides 99.5 percent UV protection but also features fade resistance anti-yellowing protecting you and your JL/JT from the harsh weather. ClearLidz special design reduces the sun's heat rays from penetrating into your Jeep allowing the interior to be 25 degrees F cooler than stock.
ClearLidz comes 100 percent assembled needing no tools to install. Installation takes less than 10 minutes to retaining factory mounting locations.
CL300 Fits Jeep Wrangler 2 and 4 door JL/JT/JLU/JTU models 2018+
Details:
- Made in USA
- 180 degree Transparent Panoramic Top
- Super durable construction providing a complete weather seal
- Keeps interior 25 degree F Cooler than Stock in warm weather
- Military grade polycarbonate (unbreakable)
- Total UV protection to avoid yellowing
- Easy Installation- No Tools or assembly needed
- Retains all factory mounting locations
ClearLidz special design reduces the sun's heat rays from penetrating into your Jeep allowing the interior to be 25 degrees F cooler than stock.Can you say green house effect.
I installed the Curt receiver hitch on my Jeep. Yes, that job was as easy as the tow harness was labor-intensive.I also added a Mopar receiver hitch today. That was the easiest job of them all.
I’ll tackle the wiring kit some other time. Haven’t bought it yet for starters. Trying to decide if I want to spend the money on the Mopar or go with something else.
Do you like these homemade ones or would you purchase the ARC door hanger for $79?I did this....works great!...
My buddy bought the arc, and it works great.... basically, it all does the same job in the end.... I had scrap wood and most things needed for the homemade one so I chose that but before that, I was using dollar store rubber coated hooks... which worked fine also....Do you like these homemade ones or would you purchase the ARC door hanger for $79?
I have a small 4x7 utility trailer and don’t anticipate towing anything else, so realistically I don’t have a need to spend the money on the Mopar wiring kit. The Quadratec is actually my front runner but I wish I could sort out a mount for the 4 pin connector. I was going to buy Quadratec’s receiver hitch also but it was out of stock.I installed the Curt receiver hitch on my Jeep. Yes, that job was as easy as the tow harness was labor-intensive.
Knowing that I would likely only ever tow a motorcycle trailer, I purchased and installed the Quadratec 4-flat tow hitch harness.
