XJfanatic
Indianapolis
2020 JLU, 2016 Navigator L, 1990 Mustang, 1994 XJ
Took her on a drive with the top down to enjoy a break in the rain. Well the ESS warning light came on with the service ESS message. Get to where I was going and pulled codes with JScan. Battery B circuit fault. Figured the AUX battery probably was on its way out.
Anyway popped the hood to take a look, and noticed the battery ground was loose. So I ended up tightening that up and said well guess I should look at the fuses, yup every fuse and relay was loose. I had never looked at them since I got it. Funny it took 32k for something to manifest.
Cleared the code with JScan and it and it has stayed off since.
klhjeep2018
Kevin
Harpers Ferry, WV
2018 Rubicon JL
Sales manager
@pixeldecals is the go to source, excellent materials and customer service. I had the wolf windshield chaser, hood graphic (still waiting to be installed) as well as the hood “Name” graphics for the other half’s. My hood graphic is a topo decal. Here is a pic of the name graphics for the other one with the topo graphic under them.
Thanks Buddy!
jeepoch
Jay
Longmont, CO
2019 JL Wrangler Sport S 3.6L Auto 2 door, 2.5" lift, 35s
Added all my preliminary communications gear to my JL. I have (thus far):
1. Amateur Radio: Yeasu FT3Dr HT - External Dual-Band VHF / UHF Antenna (call: KF0EUD). Range is potentially worldwide depending on the Repeater and operating mode.
2. CB Radio: Cobra 75 WXST (call: Snowshoe) rarely ever used anymore except on trail. Range is about a mile and a half.
3. Jeep Club Commercial: Radio: Implemented on locked Baofeng UV-5R with UHF Antenna, good several mile range depending on terrain.
4. GMRS Radios: Cobra Micro Talk PR3175 HT (not shown), 10 mile range depending on battery strength.
5. FRS Radios: Cobra Micro Talk FRS-300 HT (not shown), 1 mile range at 500 milliwatts.
6. TBD - Emergency Satellite Guard HT. Still researching...
This plus my cell-phone should keep me connected on trail (or nearly anywhere for that matter).
Spent a small amount of $$ and invested in a MFJ-310 Handheld Antenna Mount Clip for my ham HT. However after purchase, I really despised it's obnoxious placement required for the 2 door. So I came up with this alternative.
While not expecting optimal performance (based purely on antenna theory physics), due to a perceived poor ground-plane, I inverted the window mount and placed it upside-down on the back window hatch (refer to supplied pics). Remarkably though, I can easily hit repeaters 15 to 20 miles away.
Researching into this, it appears that the dual-band antenna is about 1/4 wavelength above the JL chassis. The hardtop being made of fibreglass provides no appreciable attenuation. So it looks like I have a classic vertical dipole mounted 1/4 wavelength (1.5 feet) above a good ground-plane at 144 MHz (2m). 1.7 feet would be ideal.
For UHF at 440 MHz (70 cm) again it's about 1.5 ft above ground plane for 1/2 wavelength where 1.1 ft would be ideal.
So a little less distance than ideal for the VHF 2m Amateur band and a little above ideal distance for the UHF 70cm band vertical dipole antenna mount. Life is always a trade-off set of compromises.
I'm certain I can manipulate the base plate mount and create a more deliberate ground plane by adding a conductive semi-circle plate with about a foot radius. While this will more closely match the 50 ohm feed point impedance of the coaxial feedline, why bother? How good is good enough? I'm not OCD, so the gain of this external antenna is much better than the stock rubber duck.
However, when I get the chance to connect it to an antenna analyzer or SWR meter, I'll have more information. If playing with the base mount provides even more gain, then maybe I'll dink around with it. Still, both VHF and UHF are line-of-sight propagation, hitting repeaters from my Jeep to the Earth's horizon (already) at 5 watts is pretty darn good. This antenna mount required absolutely zero drilling, and provided a very easy cable routing up to the center console. Besides, it looks clean and almost professional. A semi-hemispheric plate while providing better performance (???) would certainly look ugly as sin. I am way more of a geek, so there is that.
Now the cockpit space to mount it required a little finesse. So here I have my ham, CB, Jeep Club and cell-phone mounts. I lost the factory cup wells but found a little portable cup holder contraption I could mount on top of the console instead. A little cheesy but functional. The only real downside is that you can't now open the console with non-sealed beverage containers. Oh well... I'll clean that spill when it happens. In the bigger picture I now have access to about all the frequency spectrum (within a non governmental vehicle) that I could ever require. Certainly much more ready for the Zombie apocalypse.
How cool is that?
Jay
slimfl08
Victor
Shreveport, LA
2019 JLU Ocean Blue Rubicon
Finally got around to installing my lift and Tires!! Big THANKS to @River City Offroad and Marcus for a great deal on the Clayton lift. The K5s in Bronze from SCS look better than expected! Figured I’d see what the Carolina Squat looked like to while I was at it.
6.5shooter
William
Danville, KY
Toyota Tacoma daily, Sting Gray JLUR ordered!
I&E Technician, Crane operator
got it completely naked for the first time, added some $30 motorcycle mirrors from Amazon to keep me legal, installed the teraflex 1” front spacers pn 1155100, and re-torqued the lower balljoints (found them to be extremely loose, had a POP when turning right at low speeds).
Mx5red
Paul
San Diego
2020 JTR, 2020 JLUR, 2008 M3 (sold), 2013 JGC (sold)
Just finished setting up my iPad, iPad ram mount and Bad Elf lighting adapter in my jeep so I can wheel with Gaia GPS.
Can I ask a lazy question without researching it? I thought the iPad cellular had gps.. so is this a cheaper way to get gps on a WiFi iPad, or is the gps on the iPad not as good and this is a better alternative?
Thinman
Rich
CA
2020 JLUR, 2019 Rebel 12 and...... a 2012 Prius
On-board air. 4 Tire thingy from InnovativeAT + the under passenger seat mount
Then did a 4 awg Anderson connection under the hood
...and ran it back to the rear passenger side
...for a 1000W inverter
...so I can make coffee 😐
Ezun
Chad
St. Louis area
JLUR
Now mounted with grade 10.9 flange bolts and flange nuts. Very happy with this project as I am able to keep the stock look and feel, but the underpinnings are as strong as possible.
That is seriously impressive. Nice work.
The ingenuity of forum members here astounds me.
Mx5red
Paul
San Diego
How cool is that?
Jay
I get confused trying to figure out my handheld baofeng :LOL:
I think I wouldn’t know what to do with all those radios!
Rangemaster
Nevada
2020 JL Rubicon Diesel
Business Owner
Ipad cellular has cell phone gps, my ipad is wifi only. So I went with the bad elf plug in gps unit, so when I am out in the back country where there is no service this ipad will still get gps. Unit works great and very easy to see while driving vs my small garmin rino.
Dwayne Lane's Chrysler Jeep Dodge
