frank-o
Frank
USA!!
392 SOT, JLUR SOT, Prior JLUR Sting, 10thA JKUR
I got my Oracle LED reverse lights installed.......
Next up will be the Diode Dynamics clear side marker.
Looks great. I put the Diode dynamics clear side markers in - easy and great add. I’ll have to do those oracle reverse lights.
AZHUND
Tucson, AZ
2018 JLU Sport S, 2018 CX-5, 2020 RAM 1500 BTS
More easy ones: led halo headlights and some new wiper blades (first rain in long time in AZ reminded me the oems are junk). Does anyone have a tip for how/where to cleanly route the far corner drl wire to the fuse box?
JeepAustinWeird
Austin, Texas
2018 JLU Rubicon
Thank you. As many have referred to in this forum....the drivers side light is not an easy fit. Like another member, I ended up Dremel-ing the whole perimeter the housing on the light till I was able to get it to fit. It was a way tighter fit than the passenger side. There are several post on the forum explaining how to tap into the tow harness (if you have the tow pkg) rather than the taillights. I'd definitely do that as its easier. (White wire with orange stripe).
wibornz
Ted
lansing, Mi.
www.instagram.com
JL Unlimited Rubicon
My front Rancho skid is now slightly bent to one side at the rear. Obvious because the U bolt is no longer centred and there's a tiny crack line at the front below the diff bolts. No leaking. And I never took a really huge bang to the front. Just the usual scrapes and light bangs. Takes a licking and keeps on ticking.
Reach out to Rancho and see if they will replace it.
aldo98229
Aldo
Bellingham, WA
Market Research
Wrangler JL 360
Shawn
Castle Rock, CO
www.youtube.com
2018 wrangler JLU Rubicon
Systems Engineer
Got set of 17x10 ATX Beadlocks. The offset is ridiculous with my old tire carrier setup so Teraflex HD carrier seems the best solution for sub 400$?
Jjirish
Jenne
2021 Jeep 392, 2024 Jeep 392, 2023 BMW X7C
Lurking the forum
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
Jeep Wrangler JL What did you do TO your Jeep JL today? E604FE8C-3DE4-43E8-9D64-4F5492AEB80E
First off, nice Jeep you've got there!
You might want to consider a complete hinged tailgate reinforcement with adjustable carrier. I had the Teraflex Alpha HD, but the 38x13.5 spare was causing some creaking and noticeable sag at the hinges. I recently replaced it with the Cavfab Elite carrier. It's so much more solid and quiet now.
Jeep Wrangler JL What did you do TO your Jeep JL today? 20210117_135607_resized
