limeade
Yeah, I just read those......Be careful, seen a couple reports now of people getting the old aluminum box installed by the dealerships for the TSB.
I'll definitely check to make sure it's the right box.
Fox TS here as well. Although, I went with the SteerSmarts bracket on the axle side. It's a double sheer design, and it's vertical stabilizer bolt allows the bushing to flex radially instead of sideways.TS is the way to go! Take a look at the Fox 2.0 TS for the JK, it works perfectly on the JL-all you need is the Synergy Stabilizer Stud/Trackbar Bolt for $25 and you are good to go! Mounts the stabilizer above and out of harms way.
When I went to pick mine up from the dealer I immediately raised the hood and verified I had the correct black steering gear box. Or course after 2 turns I knew it was a different box.Be careful, seen a couple reports now of people getting the old aluminum box installed by the dealerships for the TSB.
Be honest. You just bought the Jeep to push the RV from the rear.Lots of awesome mods here. I’m probably never going to do the extreme trails many of you do—I will live vicariously through your adventures though.
The main reason I bought a Jeep was the ease to flat tow it behind our RV. We finally got it done. Tested it yesterday for a 20 mile drive. It works well.
TRUTH! LOL! Stay well.Be honest. Jou just bought the Jeep to push the RV from the rear.
The white wheels and raised white letter tires look like a product of the 70's or 80's. But I'm a product of the 70's and 80's so I have absolutely no problem with thatShe got a new set of Quadratec 17” wheels and 35” General tires
what is the reason or benefit of attaching the stabilizer to the tie rod using trackbar bolt vs using the “vehicle-specific brackets it comes with to mount in the existing stabilizer location” (per quadratec website).TS is the way to go! Take a look at the Fox 2.0 TS for the JK, it works perfectly on the JL-all you need is the Synergy Stabilizer Stud/Trackbar Bolt for $25 and you are good to go! Mounts the stabilizer above and out of harms way.
This is where it gets tricky. If you are running stock steering setup it mounts one way, if you are using aftermarket stuff it mounts differently. Bottom line, if you are ever going to upgrade your steering (highly recommended), do it first.what is the reason or benefit of attaching the stabilizer to the tie rod using trackbar bolt vs using the “vehicle-specific brackets it comes with to mount in the existing stabilizer location” (per quadratec website).
Also, your saying the one for the JK will fit and work on the JL (I’m assuming if using the trackbar bolt)? Thanks
Looks great. It is hard to tell from your photo, but make sure the top brackets go under the hood insulation for a proper fit. If you don’t want to fit them under, you can always trim the hood insulation back. *Here is what they look like with the hood insulation trimmed and the bracket properly seated.Cleaned up the engine compartment and installed Redline hood struts.
