iamstillvince
Vince
Alberta, canada
2020 wrangler sport s
I saw some LP9 knockoffs on FB Marketplace that looked almost identical for 25% of the price of the BDs. The BDs are beautiful but they are too much money!
Yeah, found 5 and 6 inch version on Amazon, canada $ 70/$100 each. They don't do dual brightness but do have orange daytime. Sure they aren't as good but more budget friendly
BernJLUR
Bern
Bradenton FL
2019 Ocean Blue JLUR (on order), 2015 Anvil JKU, 1995 4.0L YJ
DIY "No-par" satin black grill mod - gently sanded a cheap blue takeoff grill, cleaned with rubbing alcohol, spray painted with satin black, spray coated with satin clear coat. Now it's drying. Will reinstall in 48 hours when it's dried and hardened. Whole project including takeoff grill and paint ran me $85.
Two pics show gloss black OEM grill (which I was running) vs DIY No-par painted satin grill.
And it's not a mod unless there's some blood spilled. Those grill guards snap out surprisingly and violently. I'm 2-for-2 getting caught and bleeding. I suggest gloves for this part.
Lastly, I swapped my JT Gladiator grill guards over to the newly painted grill. They do make a visible difference temp-wide. Running the JL version, I was pretty much dead center on-the-line in the middle. Running the JT version, I am almost down to the next lower line. Practically, does that matter? Who knows. But there's a visible difference on the gauge for sure!
Jeep Wrangler JL What did you do TO your Jeep JL today? 94277AA0-E974-4D2C-943F-BC187F260563
Fin. I like the subtle satin tweak to the front end. It pulls the steel bumper, winch guard, and plastic flare trim together.
The gloss felt too much like the Willys and Recons coming out.
Plus DIY is always more rewarding!
Jeep Wrangler JL What did you do TO your Jeep JL today? PXL_20201211_174113683
Jeep Wrangler JL What did you do TO your Jeep JL today? inCollage_20201211_140446850
EVMIII
Bud
Biloxi, Missippi
2020 JLU Rubicon
Retired, USAF
Used my winch to pull up up two 25 year old azalea bushes. Busted a few big roots with an axe and yanked them up. Winch is really handy when you need it.
TP1
2021 JLU
Looks fantastic!
Big Red Rubicon
New York
2021 JLUR ; 2014 FLHTK
Installed Rhino Rack Backbone with Maximus 3 ladder
Nice setup! Did you drill into the body for the bottom support? Could you share a picture of the inside where you attached it to the body? I have the ladder all set to install and can't seem to figure that out.
oceanblue2019
Maryland
2019 JLUR 2.0L Auto
Metrology
Hey John, Do you know if these plug and play no capacitors needed? Amazon has these at $57.
Infinity Reference REF-3032CFX 3-1/2" 2-way Car Speakers - Pair
You need the metra adapters to not cut the factory wiring. You don't need the caps they include as they will cause popping on power up/down.
The factory Alpine amp seems to have crossovers built in for high pass to the front corners.
Note: you may need to flip polarity on the Metra adapters.
Crutchfield has them for $67 but they include the adapters so might be worth it as $57+adapters is likely to be more.
Brew211
Peoria, Arizona
2018 JLURM, Tundra, 2022 JLU 392 XR
Responded to your PM
hoag4147
Rick
Colleyville, TX
2022 JLUR XR
Thanks John. Well. I guess I need to grab some Metra’s :). Already ordered on Amazon, be here in the morning. Appreciate all the details.
Heimkehr
Pennsylvania
2021 JLU 2.0T
Red Line Hood Struts.
Rather than trying to get the top brackets underneath the hood insulation, I decided to just trim it back. I traced the outline of the top bracket with a pencil, took some small scissors and cut/removed the material underneath the bracket. While it is a small detail, now the top hood brackets fit flush.
The hood insulation must vary among model years, and/or engine choice. I didn't have to trim any of it when installing the same struts on my 2.0T JLU.
I wish I knew someone with a winch. There's three 14 yr. old bushes out front that require removal. They were really trimmed back for the autumn, but the root systems are well established and will require real muscle for removal.
WRGLR-JL
PA
2022 Willy's 2 door
Installed Rugged Ridge Spartacus bumper, took opportunity to paint bumper hooks red and swapped out my black front grill for my white OEM grill. I enjoyed the black one for a while but I like the white too.... I'm thinking I need the overrider hoop for the bumper too.
iamstillvince
Vince
Alberta, canada
An old guy like me would just snip and twist ;) adaptors didn't exist back in my horse and buggy days
AZ Hella
Sonoran Desert
JLUR
I have the Spartacus also. I like it.
Jeep Wrangler JL What did you do TO your Jeep JL today? 2E1766E9-4779-4B2C-B7AE-CC1D902FD354
RagTopDeluxe
Julie
Northern California
2020 Punk'n Recon
My Mopar wheels arrived :rock: and I spent the day painting the rings.
Sanding (hidden Mickey :CWL:):
Primer:
Paint (three-is coats of color, two clear coat):
I'm loving this! I'll be spending some time this weekend bolting the rings on (when I'm not baking cookies):
Rock Hopper
Nevada
2019 MOAB, 2019 Cherokee, 2015 GrCherokee, 2006 TJ
Retired Firefighter
Jeep Wrangler JL What did you do TO your Jeep JL today? IMG_3045-X3
Primer:
I love those rims (and color combination). However it does take a while to follow the bolt pattern on the rings and torque each one down...but the end result is definitely worth it!
Jeep Wrangler JL What did you do TO your Jeep JL today? 20200715_212232
