Hans
Hans
Jeep Wrangler Willys 2.0 4D
Now awaiting my Baja Designs Squadron fog replacements... Please hurry!
[/QUOTE]
Hello,
I'm interested in the CMM 1" ball mount .
May I ask where you bought it ?
Thanks
Grtz
Hans
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
I have the same Sahara wheels. I would like 35/12.5's.
A bunch of us, myself included, have put 35x12.5's on factory 7.5" wide wheels. The wheel being a bit too narrow isn't the most ideal for a tire wider than 11.5", but it's not by far a recipe for disaster. The narrower wheel causes the tire tread to run a bit more rounded out from side to side, which will lead to uneven wear unless aired a bit lower than normal and will also void any tire warranty from the manufacturer.
I suggest sticking to a C-rated tire, which is why I went with the bfg ko2 315/70-17's (a slightly smaller metric version of 35x12.5). Usually the 35x12.5's are only available in D or E weight ratings, which will ride harsher because they are meant for vehicles heavier than a wrangler.
Also a heads up. Tire choices are very limited for 18"wheels compared to 17's.
Shawn_1121
Shawn
New Hampshire
2020 JLU Sahara
thanks! Sorry to be a pain but could measure the height under the cargo tray? And also could you take a picture with the rear door closed but the rear glass up just want to see how much room from the tray to the door. Thanks again! You’ve been a huge help!
jbal13
Punta Gorda, florida
2018 JL Sport
Thank you. That was the answer I was looking for.
Maverick909
Inland Empire
www.instagram.com
My understanding of the clutch recall is that adding the shield for the fuel and wiring is required to help prevent your Jeep from burning to the ground if the clutch scatters. It couldn’t hurt to get @JeepCares involved with your search for a better dealer to perform the recall.
I am working with Jeep cares on this matter currently. Katlin has been helping the best she can. Currently making sure they did the work that should have been done. If they don’t I will setup a different appointment to another dealership through Jeep cares so this gets handled properly.
  • Like
Reactions: Sol
