Djmatt85
Daniel
Sacramento, CA
18 JL Sahara
I swapped out a 2” spacer lift for a JKS 2.5” dual rate lift with HD front springs to account for front bumper and winch combo. Also added RC adjustable LCAs. Definitely a little stiffer ride but a lot less body roll in corners. So far very happy with the upgrade. Can’t wait to get flexy in a couple weeks.
Jeep It
Travis
Colorado Springs, CO
2018 JLU Sport S in Firecracker Red
Had Rubicon suspension installed today, now I need some bumpers and a winch.
Carlton
Chicago
Jeeps lots of jeeps
Started wiring the LED cube lights. Haven't installed them yet. Doing as much soldering off the vehicle as possible.
Blu bi Kong
Vic
Colorado Springs
2018 Rubicon JL
Designed and fabricated my own Rotopax stoppers with a push button bleeder valve. Works bitchin
We
Well, this was an amazing piece of work for me. With my cans in the window it was difficult at best to vent them. Now, slip my finger tip onto pushbutton and pressure is neutralized. So frikkin simple
mikej
I had similar difficulty with one of the stabilizer bolts and the rear shock bolts. Some pounding on a breaker bar with a mallet finally got 'em loose.
I have a set of these skids coming, so I guess I'll have to drink milk & eat some Wheaties. Yay.
The impact gun made loosening the rears easy. There were no clearance issues in using the gun on those big bolts. But getting the leverage to turn the torque wrench while laying under it was a pain in the ass. I bet if I had even had it up on ramps, it would have been much easier.
That said, I’m quite happy with the end product. It’ll be worth your strict Wheaties diet.
melendez69
Marc
Pineville NC
2018 3.6 JLR / 2013 911 / 2013 E92 M3
Backup for The Stig
I'm gonna get 'er up on jack stands... Hopefully the gun will help & I'll have enough leverage & room to bang away with the mini-Mjolnir.
obwahn
Retired puter dork
Got my first, and only, badge installed.
Schism75
New England
18’ JLU SAHARA
Is that J-10? I would buy that over the Gladiator in a heartbeat. Too bad FCA didn’t stick with this retro look for the new Gladiator.
sheram
Stan
Athens, Ga
"Therapy Jeep" '19 RUBICON 2DR A Real Jeep
Can you tell us how you did this. FANTASTIC idea
Sand Flea
Kevin
Lewes DE
2018 JL Wrangler Unlimited, Sahara
Federal Firefighter, Retired
Installed my Redline Tuning hood struts today.
Pretty simple job that would have been done in 1/2 the time if I had not been taking photos of the process.
To begin with, the product is quality. The packaging is excellent and the full color instructions could not be any more detailed.
I was impressed right away.
All that is needed is a 1/4" drive ratchet, a short extension, and a 10mm socket.
The lower brackets are side specific and well marked. They went on first.
Next, the upper brackets go on. Follow the directions to the letter and they install perfectly.
Take note that the weatherstrip is in the way. I used a pair of needle nose pliers and gently removed the first plastic insert.
Install the upper bracket per the instructions and then pop the weatherstrip insert back into its hole.
The instructions tell you that you can trim the weatherstrip back, but I chose to leave it as stock.
Finally, the struts are installed with the gas cylinder facing up.
Gently rock the attachment point onto the ball stud (do not force it), and it pops right on.
Done!
I can recommend this product.
Icon Vehicle Dynamics
