What bumpers fit badlands winch?
harryG
Harry
n.e. pa.
2016 renegade, 2021 willys (on order)
Probably putting the cart before the horse, but I picked up the Harbor Freight badlands 12000 lb winch today. Now I need to find an appropriate front bumper. I have a 2021 willys 2dr. So its time to turn to the experts here for your advice/suggestions. Its pretty heavy, but my willys a soft topp and plans for removing the rear seat is already a consideration. Greatful for all help. Thanks In Advance. HarryG
mnjeeper
MN
98 TJ, 2021 JLUR
Rugged Ridge XOR does NOT...already made that mistake.
LOD signature does I believe. Basically, you want something that can accommodate a Zeon.
harryG
Harry
n.e. pa.
thanks much
Cahlheim
Missouri
2021 JLUR 4xe, 2019 JLUR, 2013 C63 AMG
Technology
The Rugged Ridge Venator front bumper will technically hold it, but it doesnt fit well. Good enough for sure, but if you’re looking for a perfect fit, look elsewhere.
harryG
Harry
n.e. pa.
wound up purchasing a Vijay steel bumper from Amazon. fit onto wrangler as well as winch monting fit perfectly. Only issue is LED lights need to be spliced onto fog light wires. very happy with set-up. pics to follow.
New4xeMan
NJ
2022 Jeep Wrangler Rubicon 4xe
What's wrong with the fit? Is the wiring pinched between the grill and the winch? I just ordered a Venator and have a Badlands 12k I plan to install - just wondering what I am in for.
Cahlheim
Missouri
Technology
Pinched wiring is one issue, but reasonably easy to mitigate, and I think it existed with a number of winches regardless of the bumper.
My main struggle was the bumper is modular and acts as a clamshell around the winch. The physical dimensions of the winch do not allow the bumper to fit together as it is intended. It will “fit” but you’ll need to fight it a bit and the gaps between the upper and lower sections end up being wider than expected. The other issue is that the handle for the clutch needs to trimmed so it can be fully engaged or disengaged.
best I can do to illustrate what I am talking about.
You can see what the gap is supposed to look like with my wife’s 4xe (since we haven’t installed her winch yet), but you can see just how wide it is on mine.
Jeep Wrangler JL What bumpers fit badlands winch? CEB98A56-49C9-4F6D-BF5B-49C1E10026EF
Jeep Wrangler JL What bumpers fit badlands winch? C494A75C-FD53-4787-AD20-BC9C28CBA1B5
New4xeMan
NJ
I see exactly what you mean, thanks for such a detailed response.
Doesn’t look bad TBH and without comparo photo I might have never noticed. Mine will probably look just like yours - already have the winch and bumper is on the way.
Is it the top cover running high riding on the winch body or the lower section pushed downward? Wondering if you can”relieve” it a bit with a grinder for a better fit?
Cahlheim
Missouri
Technology
It is acceptable for sure, but like I mentioned above, if you are looking for perfection, you may take issue with this particular combo. It doesn’t bother me at all - and like you said, side-by-side is where you really notice.
As for which piece is the flex point, it is definitely the top portion. The included winch plate provides enough rigidity to force the top to flex.
cant wait
kool beenz
missouri
2019 jeep wrangler sport 2 dr with bells
operations
I purchased thru Amazon a Tyger package Front bumper TG-BP6J800068 $ 461.00 --Tyger Rear bumper TG-BP9J81198 $299.00 and Smitty built( the winch bolt area is not a drop down hidden) amphibious 10,000 lb top mount(no issue on cooling air flow) $599.00 I know you are looking priced for a 12,000 lb. capatible. The install was easy. Hope this helps. I did a lot of research by company and spec prior to buying.
New4xeMan
NJ
Just curious - I noted in the installation instructions for the Venator they mention needing to use the winch spacers for the Warn Zeon winch (which is dimensionally larger than the Badlands 12k winch). Did you try installing those spacers to lift the winch a bit to possibly provide a better fit?
Traveller128
Robert
Oasis Idaho
2022 Willys 2 Door 6 speed
Volvo Master Technician
I tried the Venator and Badlands on ours a couple months ago. The upper plate portion of the bumper, hits the front of the winch. I ground off a bit of the winch case (the upper squared off edge) to gain a little space, but it still hits and is very tight. Raising the winch will make it worse.
Also, the rear wiring exit from the winch interferes with the grill. The Venator bumper doesn't leave any room for a winch that has the heavy wire exiting the rear straight out. I ended up drilling a hole in the right side of the case, then used a grommet for the cable exit. I was able to install it without it rubbing the grill, but it was so close that getting the grill out to replace would probably require removing the winch.
We ended up removing the whole setup due to the weight/balance issue causing weird handling behavior and much reduced fuel mileage.
I really wasn't happy with the way it all went together. A smaller case winch would have worked better.
New4xeMan
NJ
Venator bumper with Badlands APEX 12k winch. Fit is very tight, but I managed to get a decent fit cheating the top bumper cover forward slightly (about 1/4"). Alignment is good and everything fit. Wiring is a bit tight between the winch and the grill, but I am going to leave it for now.
Jeep Wrangler JL What bumpers fit badlands winch? 98B298E7-73B3-4A80-9B4A-BF2FF14D5C90_1_105_c
This pic shows better the alignment
Jeep Wrangler JL What bumpers fit badlands winch? FAA06503-12A3-4930-8F3E-EDA18C76BCCB_1_105_c
I might grind 1/4" off the top[ cover where it hits the winch later if it bothers me, but for now I am happy and everything works properly.
