I'm confused and just wanted to clarify. Your dealer said that mud is getting in through those plugs and causing a rear main seal failure?I just had same problem diagnosed and confirmed this morning from dealer and it turn out to be a rear main seal failure. 11k. Miles. Dealer states the cause is mud getting in thru transmission case plugs.
Yep, spoke to service manager this morning about it. He also stated that they would only repair it this 1 time under warranty as Jeeps are not designed to drive through mud or water that would touch axles!I'm confused and just wanted to clarify. Your dealer said that mud is getting in through those plugs and causing a rear main seal failure?
That's a lie. Open up the back door and point at the the Jeep Badge that has the water tread. Goes past the axles. lmfaoYep, spoke to service manager this morning about it. He also stated that they would only repair it this 1 time under warranty as Jeeps are not designed to drive through mud or water that would touch axles!
Not hardly leaking but a couple of drops every now and then it seems. Didn’t smell the fluid so not sure. Will check it later.How bad are they leaking, and what does the liquid smell like?
I have a 21 JLUR with about 300 miles on it. I noticed the bolts looked a little suspect and took a close look at that area. I pulled the plugs out and it looks like there was some sort of grease around there. When I stuck my finger in the inspection hole, it feels oily/greasy, but it definitely does not smell like motor oil. It had more of a lightweight grease smell to it, almost like axle grease. It was also colorless. Also, nothing was pooled on the bottom, just a thin layer towards the transmission side of the flywheel.
If it smells like motor oil, it's probably the rear main seal. I would be curious to hear if it has a smell to it.
EDIT: btw, those plugs pop out and are put back really easily. Just pull them out and use your thumb in the middle to pop them back in.
Wasnt going to argue with the dealer as my Jeep has already been there for a week and will be there until late monday or tuesday at the earliest.That's a lie. Open up the back door and point at the the Jeep Badge that has the water tread. Goes past the axles. lmfao
Jeep dealers are a joke.
DODGE=Drips Oil Drips Gas EverywhereNo fluids should ever be leaking on a new vehicle.
Jaguars and Land Rovers excepted.
MOPAR= Most Our Parts Are RebuiltDODGE=Drips Oil Drips Gas Everywhere
Please keep us updated. I know you have a lot more miles on yours, but I'm wondering if there was some sort of rust prevention that was on the parts causing my weird stain and the inside be a little grease.Not hardly leaking but a couple of drops every now and then it seems. Didn’t smell the fluid so not sure. Will check it later.
