morricus
I recently bought one of these to protect my oil pan and the Fumoto valve I have installed. I'm just starting down the rabbit hole of taking my Jeep on the trails and the mods that go along with that, so I didn't want to spend a ton. Found this skid plate for $106 shipped, looked perfect. (Westin part 42-21095)
A few days ago, it arrived and I immediately ran out to install it. The install is extremely straight forward, an easy bolt on. But the instructions and pictures made no sense. One part in particular kept stating that I was to install the back of the pan using an M8 nut on the passenger side OEM threaded-stud bolt that connects the engine to the trans. I had no such bolt. Or I should say, there was a bolt, but it certainly didn't have a threaded part to allow an M8 nut to screw into the top of it.
I called Westin and explained what the my problems was, that perhaps I was missing something. The Westin support rep was confused as well, and asked me to send a picture of my set up. I did so, and he sent it to an engineer to review. I got a call back in about 10 minutes saying that my Jeep had a completely different bolt than their in house Jeep has. I don't have a threaded stud on the OEM M10 bolt, which is needed to secure the rear of the skid plate. I have a 2018 Rubicon with the 8 speed...which is exactly what Westin has, but this one bolt is different, which is what they designed the skid plate around.
I had some extra washers around that fit the OEM bolt, and used about 4 of them to fill the space that exists between the skid plate attachment ear and the back of the engine. Fit just right. I also measured the 4 washers and sent this, along with a bunch of pictures to Westin. They made a spacer that day, and over-nighted it to me with two new, longer M10 bolts. Worked perfectly.
I'm very happy with the skid plate; its solid, low cost and the support I received from Westin was awesome. I'll be buying more from them in future. Westin said my Jeep is the first they've seen with this missing studded bolt, so perhaps its a fluke. Kinda weird regardless. I would still recommend this skid plate, you just might to contact Westin for the spacer if you have different bolt set up I do.
