Went 4.56 but should I have gone with 4.10 gears?
Pullen724
Conroe Texas
2019 JLU Sport S
Ive got a 2019 JLU Sport 3.6 AT with 35” Ridge grapplers that measure right at 34” true height.
Recently regeared to 4.56 but my RPM’s are 350-400 RPM’s higher in 8th gear than the stock setup (stock tires and 3.45 gears).
Trying to see if I would be better off going down to 4.10 gears for better highway use and MPG. Would it make much difference on my RPM’s to go from 4.56 to 4.10? Would I lose 8th gear again?
This is an on road only vehicle.
Any long term issues running 350-400 RPM’s higher throughout various speeds compared to stock?
Here are my stock #’s as well as after regearing to 4.56
With stock tires and stock 3.45 gears:
50 - 1250 rpms
60 - 1500 rpms
70 - 1800 rpms
80 - 2100 rpms
After 2” mopar lift, “35”” Ridge Grapplers and 4.56 gears:
50- 1600 rpms
55- 1700 rpms
60- 1900 rpms
65- 2100 rpms
70- 2250 rpms
75- 2300 rpms
80- 2500 rpms
All speeds are MPH and in 8th gear.
Jeep has great acceleration, uses 8th gear consistently through all normal speeds and feels good with the 4.56 gears, just concerned about the higher RPM’s.
Thanks in advance for your thoughts
cb4017
Cliff
Northern Nevada
2021 Gladiator Sport
You will not hurt anything running those RPM. If you like the way it drives then enjoy your Jeep.
rkj__
Ryan
Ontario, Canada
Sierra, Countryman, RZR
4.10 gears might have been better, but what's done is done. The RPMs you listed are still within a reasonable range IMO.
UKCATS
DFW
2020 JLUR Recon/2020 Mazda3 Hatchback
I play piano in a whorehouse
I was running 4.88’s with 35’s and found it perfect for my tastes. As others have said, you are mine and made the right choice.
roaniecowpony
Retired Engineer
I sure wouldn't change gears for such a small difference. Next time you need tires, you could go up to 37s, but it will be a bit more sluggish.
entropy
Foothills of the San Gabriels
Jeep Wrangler Sport S JL 2-D
Professional dancer/male stripper
Take that poor Jeep to the beach at least. All this trouble just for the road? give it 1 day of freedom :flag:and stop worrying so much about +-1 MPG. If you worry so much about MPG why get a Jeep in the first place AND put 35s on it!
DanW
Indiana
50 - 1250 rpms
60 - 1500 rpms
70 - 1800 rpms
80 - 2100 rpms
50- 1600 rpms
55- 1700 rpms
60- 1900 rpms
65- 2100 rpms
70- 2250 rpms
75- 2300 rpms
80- 2500 rpms
With 35's, you probably got it pretty close to where a Rubicon would have been with stock gearing, so you should be good to go. It would have been great with 4.10 gearing, too, but I think with 4.56, 8th gear will actually be where it should be, and it will now be more useful. I've got 4.10 gearing with 35's and the manual transmission and While I'm very happy with it, 6th gear is really only good above 60mph. It isn't bad, but I'd love to have 4.56 gearing to get shorten up both 5th and 6th a little. For me, anyway, yours is probably geared right at the sweet spot.
Don't worry about that 3.6. It loves to live at higher rpm, so I doubt that will actually result in less fuel economy because the engine won't be working hard, at all.
Jeep’n Jay
Jay
Salt Lake City
2018 JLU Sport
4.56 is only way to go for 35's, several have been unhappy with 4.10's and 35's
InvertedLogic
Denver, CO
20 JTR
You're only 200rpm higher at 80mph than what a stock Rubicon sits at. I wouldn't sweat it. Enjoy the acceleration!
Bluebeast
Travis
NorCal
2018 JLU sport
If you don't mind me asking, about how did the regear set you back?
