Crowbar
I have the Next Venture rock sliders that need to be welded to the frame of a 23 JLUR 3.6L with Etorque. What all needs disconnected prior to welding? Typically the battery always gets disconnected but what about this Etorque battery thing? Is there a way to disconnect the Etorque battery? And connect the ground close to where the welding is being done. Do you drop the gas tank to weld on the gas tank side of Jeep?
Also, after welding of course the frame, welds, and slider mounts get painted. What should be done for the inside of the frame tubes since the welding would burn off any paint or anti-corrosion coating on the inside of the frame tubes? Don't want the frame to rust from the inside out.
