Good info. I’ve currently got bolt on both front and rear.
Do weld on skids make it any more difficult to install or remove the arms?
This was a big part of my concern regarding weld on skids. Thanks for sharing.YES! The first mod on my JLR (while waiting on special ordered suspension parts including all 8 Teraflex IR arms) was to allow the shop that ordered the parts (they knew I would be installing them) to talk me into letting them install Artec weld-on front LCA skids...(My welding skills are so-so at best...) This was one of two big mod mistakes... (Other mistake was also pushed by same shop-Synergy Sector Shaft Brace which I removed before even driving with it installed...) With the weld-on skids installed it was impossible to remove the OEM arms and there was zero chance of installing slightly wider aftermarket arms! I had to cut a thin slit down right down the middle of the bottom of the skid and then use a chisel to spread the mount enough to remove the OEM arms and install the new ones. (I cut from the Artec logo rearward) PITA! There is zero excuse for any reputable shop that specializes in Jeeps to not know this would be an issue...Pretty much caused me to lose faith regarding any recommendations from this shop since...Still, if I had taken the time to first look underneath I should have foreseen the problem-this is why I am not naming the shop!
Luckily I have the skills, tools and patience to install all of the other mods myself! (Previous life I was a Chrysler tech, then certified Mercedes tech, shop foreman and finally General Service Manager of a large Mercedes dealer)
I have the Rancho (had them powder coated black) bolt-on rear LCA skids and like them a lot, they are 1/4" steel and fit tight to the bottom of the OEM mounts. (Several other bolt-ons I looked at had up to a 1/2" gap between the bottom of the OEM mount and the skid-wasted ground clearance!)
I'm thinking about welding the metalcloak skids on my front LCAs of my JLRU.YES! The first mod on my JLR (while waiting on special ordered suspension parts including all 8 Teraflex IR arms) was to allow the shop that ordered the parts (they knew I would be installing them) to talk me into letting them install Artec weld-on front LCA skids...(My welding skills are so-so at best...) This was one of two big mod mistakes... (Other mistake was also pushed by same shop-Synergy Sector Shaft Brace which I removed before even driving with it installed...) With the weld-on skids installed it was impossible to remove the OEM arms and there was zero chance of installing slightly wider aftermarket arms! I had to cut a thin slit down right down the middle of the bottom of the skid and then use a chisel to spread the mount enough to remove the OEM arms and install the new ones. (I cut from the Artec logo rearward) PITA! There is zero excuse for any reputable shop that specializes in Jeeps to not know this would be an issue...Pretty much caused me to lose faith regarding any recommendations from this shop since...Still, if I had taken the time to first look underneath I should have foreseen the problem-this is why I am not naming the shop!
I did Artec weld on. The control arm doesn't drop out. But it does pull out. It's a little inconvenient but not a big deal.I'm thinking about welding the metalcloak skids on my front LCAs of my JLRU.
are you saying the control arm can't be removed if I do so? Even if I pull it out backwards? Which skids did you weld.
