Jamrock
A grinding sound in the wheel can be caused by worn wheel bearings. If you swap the wheel with one in the front, do you hear the sound in the front?
It’s a bit different. Not as “uniform” if that makes senseIt is sort of a grinding noise actually, go to page 29, and watch the video:
https://www.jlwranglerforums.com/forum/threads/knock-in-rear-with-dana-44.16921/page-29
See if you have a similar noise.
Best way to check is to just jack up your rear wheels and spin them.
The sound is still there, at the rear even after tire rotations.A grinding sound in the wheel can be caused by worn wheel bearings. If you swap the wheel with one in the front, do you hear the sound in the front?
That was my Jeep. The noise you described and when it happens was the same. It would disappear at higher speeds, but would occur at low speeds. Dealer thought it was wheel bearings, but once they opened the pumpkin, the gears were chewed up. They replaced the whole rear axle. Fixed.It’s a bit different. Not as “uniform” if that makes sense
Ok might be it then. Did you have the rubicon Dana’s 44?That was my Jeep. The noise you described and when it happens was the same. It would disappear at higher speeds, but would occur at low speeds. Dealer thought it was wheel bearings, but once they opened the pumpkin, the gears were chewed up. They replaced the whole rear axle. Fixed.
It's a Sahara with the 44's.Ok might be it then. Did you have the rubicon Dana’s 44?
Sport and Sahara models get the 44 rear when they opt for a limited slip differential. Their issue seems to stem from the lsd clutches wearing prematurely and that large amount of grit is making a mess of all the associated hard parts.Ok might be it then. Did you have the rubicon Dana’s 44?
Yes there is no pattern to the sound. The parking brake would make sense. ThanksSport and Sahara models get the 44 rear when they opt for a limited slip differential. Their issue seems to stem from the lsd clutches wearing prematurely and that large amount of grit is making a mess of all the associated hard parts.
The open diffs on our Rubicons wouldn't be afflicted with that. Also, their noises are cyclic, while yours is more sporadic.
I had thought about the parking brake the other day, but not yet being familiar with how jeep set that up, I didn't want to send you on a wild goose chase. But... now that you mentioned it not working as it should, I would definitely check for any loose or missing retention hardware. Again, I'm not sure how jeep laid things out with the parking brake, but my older pickup has a pair of shoes that are housed in drum that is machined into the interior of the rear brake discs. It's a one piece designed rotor that is noticeably wider than the front rotor because of that added emergency brake drum. If jeep uses that same rear brake rotor/drum combo, the shoes would have a few springs and clips per wheel end that may have been compromised.
I took it last week and they said that it was mud on the brakes lol but I have a new appointment for next week.If its easy to duplicate, why not just take it to Jeep? I had some crazy squealing coming from the rear end and they ended up replacing an oil seal.
