Weird noise from rear passenger wheel
JlRubicon13
Davi
2 door wrangler rubicon
Hi,
Noise coming from the rear passenger wheel when driving at low speeds. The noise seems to be coming from the wheel or the wheel area. It goes away with speeds above 10 mph and is loudest when coming to a stop, right before the jeep stops. Jeep has 10000 miles and has been doing it since the beginning although it got worst. Anyone got any ideas? Video from the noise here
Thanks,
Davi
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
Something is definitely not happy. I'd pop the rear diff cover to see what's going on in there. Also, have in raised on jack stands to check for excessive up/down play in the pinion shaft bearings and wheel end bearings. That hollow thud sound is from something hitting the axle housing.
JlRubicon13
JlRubicon13
Davi
Thanks for the reply, I’ll jack it up and check. But if it was something inside the axles wouldn’t it get louder with speeds? Also the noise is not always there, it comes and goes.
Headbarcode
LI, New York
It really just depends on what's going on in there. It's kinda like driving over a washboard section of road. If you crawl over you bounce around in your seat, but if you go fast enough it isn't felt as much or at all.
JlRubicon13
JlRubicon13
Davi
Ok, I will check it out.
Headbarcode
LI, New York
Wish I could be of more definitive help. It can be difficult when one can't put hands directly on an issue. My experience is with the family business of truck and heavy equipment repair, but I've yet to really dig into and figure out the mentality of the wrangler.
JlRubicon13
JlRubicon13
Davi
Ill Probably only have the chance to jack it up and check everything on Monday, but once I do it Ill let you know what I find inside. Really appreciate the help.
Headbarcode
LI, New York
Before popping the diff cover off, you could start with a less invasive approach. Remove the back wheels and check for excessive movement in the wheel hub bearings and give a good look for anything out of the ordinary on the axle ends.
Also, is your jeep stock or modded?
JlRubicon13
JlRubicon13
Davi
Ok that’s better, also the noise seems to be coming from the passenger rear wheel, not the pumpkin so the bearing may be the problem. Yes all stock besides a bumper and winch.
Headbarcode
LI, New York
I've played your video several times between my phone and tablet, but don't have computer speakers or a decent set of headphones to really bring the sound to life.
Fingers crossed that it's something simple!
JlRubicon13
JlRubicon13
Davi
I hope so. Ill try to get another video of it today.
JlRubicon13
JlRubicon13
Davi
Hmmm...
That issue affects non-Rubicon models with the anti-spin differential rear axle. He appears to have a Rubicon.
https://www.jlwranglerforums.com/forum/threads/knock-in-rear-with-dana-44.16921/
Thanks for the reply. Yes it is a Rubicon. I've read through the thread but mine appears to be more of a grinding noise on the passenger rear wheel than a knock on the diff. I will try to get another video later today and if I have the chance to put it on jack stands and remove the wheel.
Arterius2
Jerry
Vancouver, BC
2018 JLU Sahara 2.0L
It is sort of a grinding noise actually, go to page 29, and watch the video:
https://www.jlwranglerforums.com/forum/threads/knock-in-rear-with-dana-44.16921/page-29
See if you have a similar noise.
Best way to check is to just jack up your rear wheels and spin them.
Superchips TrailDash 3
