Weathertech Mudflaps on Xtreme Recon
Machete-LC
Central, NM
2021 Jeep JLUR, 2015 Ram Power Wagon
Can you post a photo of the flaps on your JLUR when you get the chance? I drive on a gravel drive frequently and need to control the rocks throwing once back on the hard road. Thanks.
Jeep Wrangler JL Weathertech Mudflaps on Xtreme Recon 4AA2C05C-A1CB-4FB1-8980-AD49E15F7631_1_102_o
Jeep Wrangler JL Weathertech Mudflaps on Xtreme Recon E5DD230D-A455-495F-BB79-C3B89102AE6F_1_102_o
Hey Daveski, I hope these upload. If you need a different angle let me know. Unfortunately, I got the LOD sliders after I opened the cutout for the standard Rubicon Sliders so I have a hole where the OEM sliders went. Overall they still do a great job.
Daveski
Maryland
2022 4-DR Wrangler Rubicon XR
Thanks for the photos. I'm gonna at least get flaps for the front without a cutout. I have NFab steps that don't go as far forward as the XR sliders.
Machete-LC
Central, NM
Glad they helped! The wife and I scooted around Yellowstone and the Grand Tetons in May this year for about a week in snow/rain/sleet and they kept the mud and grime off the sides of the jeep. This is nice and it keeps your clothing (and more importantly my wife's clothing) from getting mud and grime on them. I know that is a bit lame for a "hard core" offroad vehicle but that is why the RokBloks are a nice option.
Marine2146
North Carolina
2023 Grand Wagoneer 3 series, 2022 Rubicon 392
Not an XR but I have ordered flare extension I plan on installing. The weather tech front splash guards are an extremely easy install no need to drill, just push the center of the rivet in before using a pry tool to remove it. Hardware all fit correctly, they must have updated it at some point. They work just fine with the rock slide engineering step sliders. Running AEV splash guards in the rear. Wheels are 9” wide with a +1 offset for reference.
Jeep Wrangler JL Weathertech Mudflaps on Xtreme Recon 672F0F1E-158E-401F-BE64-BEE8DEBEE17B
Jeep Wrangler JL Weathertech Mudflaps on Xtreme Recon 56C8B62D-55EB-43FA-B615-030733A56793
Jeep Wrangler JL Weathertech Mudflaps on Xtreme Recon 39B5B777-02FA-435A-AC16-5B33614503B8
Jeep Wrangler JL Weathertech Mudflaps on Xtreme Recon 48E4C7D2-1B1D-445F-B2A0-D30ED3A738BF
Jeep Wrangler JL Weathertech Mudflaps on Xtreme Recon A77EE73D-5022-45F4-B905-0AB982E67665
Jeep Wrangler JL Weathertech Mudflaps on Xtreme Recon EFE3D97B-A902-4C61-9CC4-B7F8A733520A
Daveski
Maryland
I ended up going with the Rokblokz XL for the front. You can get them with the cutout for the rock rails if you have them, I got them without cutouts since the NFab nerf/steps didn't go as far up as the XR rails. I needed something to protect the front of the nerf/steps. Hell, it sounded like a windchime after leaving the gravel.
https://rokblokz.com/collections/je...018-mud-flaps-half-kit?variant=15701151842347
Jeep Wrangler JL Weathertech Mudflaps on Xtreme Recon DLB_3948
Jeep Wrangler JL Weathertech Mudflaps on Xtreme Recon DLB_3949
J_Winslow
Jeremy
Virgina
2022 Rubicon Xtreme Recon
I found the spray to be quite low... this us after a day of wheeling with a fair bit of mud... others were to the point you could hardly tell what color the jeep was
Jeep Wrangler JL Weathertech Mudflaps on Xtreme Recon 20220710_180308
DRockWilson
Derek
Cleveland, OH
2022 Jeep Wrangler Unlimited High Tide
I bought and installed the WeatherTech Rear Mud Flaps on my XR without any problems, but damn I'm having a hard time with the front getting off the plastic rivets. I assume I have to remove the bottom 3 rivets (2 standard from the directions and the middle of them from the XR fender flares) to be able to pull back the trim to install the U brackets. I've tried using a trim removal tool and trying to use the center punch thing of the rivet with a small screwdriver with not much luck. Any tips?
CO_Jeep
CO_Jeep
Denver
‘22 392 XR
The bottom two from the liner should be pretty easy with the trim removal tool, the other rivet I used a small drill bit to the center of the rivet, then used the trim removal tool to pull it out. Stay patient, I hope that helps!
This tool is also helpful if you are willing to wait for delivery.
https://a.co/d/53ULkXf
DRockWilson
Derek
Cleveland, OH
Thanks. The pliers part of that tool looks very useful. I just have a standard trim kit that is being difficult to get under those rivets. I am worried about gouging into the plastic too much. I know it will be covered by the mud flaps but still trying to be careful.
Jmos4
2020 Challenger Scat Pack M6/2007 Ram 2500 G56
Hi,
I used a punch a few I had to grind flat or even dimple slightly to make sure the punch hIt the post
regards,,
Shanwowsd
shannon
San Diego
Jeep
I had trouble with the middle rivet on my XR. I ended up drilling it out on both sides. the rest of them popped out with trim tool no problem. the first side took forever since I was cautious and not wanting to damage anything. 2nd side was super fast.
DRockWilson
Derek
Cleveland, OH
I got the bottom one out with a little effort but struggled on the other two. I'm sure once I figure out the tricks it will also move along faster.
DRockWilson
Derek
Cleveland, OH
Well I think I figured out my problem and all I had to do was read correctly. I couldn’t get the front ones to line up for the life of me. I bought the front mudflaps for the Sport S bc that’s what the high tide is based on. I should have read the OP post better bc I should have bought the rubicon version of the mud flaps. Pretty sure the high tide has rubicon fenders. These aren’t wide enough to match up all the bolts. Ugh. So frustrated.
Old Dogger
Cave Creek Arizona
I installed them on our JLR, but front only. Very easy install. They sure do save on the paint.
Taco2Rubi
Ryan
WV
'24 JLUR-X High Velocity
Just to clarify...are there any flaps that work on a Rubicon with the factory installed MOPAR Performance Rock Rails? IF so, could someone please let me know which ones work?
