Warranty Repairs
Mojito!
E TN
2018 Sahara Unlimited JL
I was wondering how many of you have had repairs made under warranty and what they were. And of course when.
I had both batteries replaced at 11 months. Caused all kinds of crazy displays.
The sound bar replaced on the right side because of a stripped screw. I first brought the buzzing to there attention at 11 months as well. It was finally fixed at 17 months after I couldn't stand it anymore.
jeepster345
Hunter
Homestead, FL
2018 Jeep Wrangler JLUS
I had both batteries replaced as well at 8,700 miles. Other than that, Iā€™ve had a great experience.
Sean L
Sean
North Carolina
Main Battery replaced at 28,000 miles or so. Kept going into battery protection mode instead of doing auto stops.
GreyFox
Brandy
Ohio
17 JKU, 19 JL
Rear shocks started leaking within 30 days. Replaced with no problem. Broken center console latch after 9 months or so. Replaced with no problems. Other than that, no problems. And if there are then I have another 22,000 miles or 18 months to get it fixed:like:
Kraty1
Batavia IL
2018 Jeep Wrangler Unlimited JL
Sales & Marketing
Rear window replaced due to detached defroster wire, drivers door wire harness fixed due to bent pin, several recalls done, 3 correct oil changes and tire rotations and even free loaner vehicles when needed. All without issue.
viper88
Nick
IL
Only the steering stabilizer recall after 13 months.
wordslayer
grand cherokee
Backup camera replaced at 2800 miles
Stereo replaced at 3,000 miles
Key Fob replaced at 3800 miles (how does a key fob go bad)
By 122,000 miles, I should have a new jeep
dj3513
New Jersey
2019 JL Sahara Unlimited / Granite Crystal Metallic / Sky Oneā€“Touch Power Top
18,500 miles . PCM and center console latch. ( And stabilizer recall )
HiJinx69
Richmond, VA
2018 Wrangler Sahara Unlimited JL, 2014 Mazda 6, 2010 Honda Odyssey, Yamaha FZ-09
Steering gear.
Rear axle assembly.
Radiator.
All done before 10K miles.
JeepersCreepers2
Northwest Arkansas
2018 JLU Sport S
Replaced D44 rear axle at 11k miles. Seems to be an issue for more than just me. Luckily the repair was quick and now runs like new
JeepDave
Chicagoland, USA
2019 2D Sport, V6, Manual Transmission
2019 2-Door Sport
Mileage Item
9838 V41 Recall - Steering Dampener - no biggie
10343 Right Rear Cargo Hook - no biggie, actually my fault that it broke
12409 Auxillary Battery - thought to have caused the 'Service ESS System' error light
13044 Clutch Interlock Switch - really what was causing the 'Service ESS System' error
14566 Left Front Seat Adjuster - a real pisser - stuck in Atlanta for 2 days while new front seat frame came in, front seat would not slide, couldn't drive home -
More to come...
W12 - Clutch Recall - to be scheduled
Front Defroster - will inquire
Rear Differential - ?? possibly knocking, but I'm not sure - thanks forum.
Windmutt
Scottsdale,AZ
2018 Jeep Rubicon JL
My Jeep has been in the shop 6 times for the Battery Protection mode issue. Corporate just says they are sorry and will provide an update. I called an attorney and found out that we all have an option to resolve the issue if it isn't repaired in a reasonable amount of time based on your state's lemon law. 27 days and 6 times in the shop is considered unreasonable in my state so I am elevating this issue. It's unfortunate that Jeep just doesn't seem to care.
