Saejin
- Gene
- Mar 2, 2018
- Colorado Springs
- JLUR - Firecracker Red
Just wanted to share my experience and help others from making the same mistakes I did and also let them know some tips on making it easier.
First of all there’s a great video here posted by a user who goes through step by step in the install. I watched it a few times and it helped me out a ton.
- get a torque wrench...you’ll need to torque some bolts down, especially the bumper bolts and the bolts holding the winch to the winch plate.
- warn’s Winch Plate is a good piece of work, but it’s a bit more complicated than other since it has multiple pieces. Just keep all bolts loose until you fit everything back together...use the zip ties to hold the plate in place since the bolts won’t be tightened yet
- you’ll need to mount part of the winch plate to the brackets that the front skid plate mounts too. These mounting bolts are soft, so don’t over tighten them. I did on one side and probably stripped out one of them. I’m not too worried as this only holds the skid plate and not the winch. It’s just used to position the winch plate. The bulk of the pull from the winch will be where it bolts to the bumper/frame bolts.
- your front skid plate won’t fit after you install the winch plate. It’s about a 1/4 inch off on the rear bolts. You’ll have to drill new holes where the two rear mounting points are.
- the Zeon is a tight fit. You’ll have to lean it to one side and slip it in. If you don’t you’ll scratch it trying to get it in...trust me.
- make sure you have the JL ready Zeon or install the 90 degree clutch before starting. If not you’ll have to disassemble everything again to install the new clutch kit. You can use 1/4 spacers and probably get by, but warn will send you a new clutch kit for free.
- clutch kit was easy to install even though I did it wrong. The gears came loose on mine, but I was able to get it all back together. Again there’s a great video posted here somewhere on how to do it.
- the opening on the rubicon bumper where the fairlead goes is kinda small. Almost to the point I think the rope will rub on it depending on angle of recovery. This is something I’ll be looking at when I put it to use. If it does rub I’ll probably cut the opening up a bit more. I only want the winch rope touching the fairlead.
- you can’t use the Aux buttons to turn the winch on and off. However you can buy a warn power interrupt kit and use the aux switches to cut the power to the winch so it’s not always receiving power from the battery. It’s an added safety measure. I may get one and add it.
- when pulling the bumper off rotate it up and down and pull it off...not side to side...it doesn’t come off easily if you pull the right side out further than the left and vice versa.
Good luck.
Good luck.
