J.Ralston
Hello everyone!
I have a 2021 JL Jeep Wrangler Unlimited Rubicon with the 3.6 liter V-6 and 8 speed automatic transmission. When I ordered the Jeep, I knew that I would be off roading it a lot and knew that I would be adding a winch and off road lights to it. As a result of that, when I ordered my Jeep, I ordered it with the steel bumper group and whatever other option that it was that made the Jeep come with the 4 auxiliary switches that come pre wired into the Jeep. With Jeep doing that, I thought that was a great idea on their part!
Here’s the deal. I have ran off road lights on my Toyota Tacoma 4x4 trucks before and have a good understanding of how they are supposed to work and get wired up. However, I have never ran a winch on any of my vehicles before so this will be a first time thing for me.
With my winch, I know that I can simply hard wire it in to the battery or I can wire it into 1 of the 4 auxiliary switches that are already pre wired into the Jeep. If I wire the winch directly into the battery, does it stay continuously on or does the winch itself also have a power on/off button?
If I wire the winch into 1 of the 4 auxiliary switches, which one do I need to wire it into considering that auxiliary switches 1 and 2 are for 40 amps I believe? And switches 3 and 4 are for 15 amps I think? Also, if I went the route of wiring the winch into 1 of the OEM auxiliary switches and the winch also had and on/off switch as well, could I leave the winches switch left on at all times since the auxiliary switch will also be controlling the power or would I also need to leave the winches on/off switch flipped to having the power off at all times when it is not being used and then when I decide to use it, turn the winch powered back to on as well as the auxiliary switch as well, that it’s wired into?
Thank you everyone for your help. It’s much appreciated!
J.
