Warn Zeon 10-S Synthetic Cable Issue...
Dreadnought_Leviathan
Robert
Dallas, Texas
2018 Jeep Wrangler Unlimited Rubicon
Finance
Hi all,
I installed a 10-S and used it on the trails for the first time this past weekend. The red cabling that surrounds the core black cabling of the synthetic cable split on me somehow. I think it’s because of my improper spooling of the cable.
My question is, can I still use the cable reliably without any issues? From what I’ve read, the red cable adds extra towing capacity. The black inner cable is still alive and kicking.
Here’s a pic of what part of th cable I’m talking about. The red part wraps around the inner spool.
Before you tell me that I need a new cable, please understand that I’m aware of that. At $300 a pop, what I want to know is if I’ll still be ok with the cable I have currently.
Jeep Wrangler JL Warn Zeon 10-S Synthetic Cable Issue... EDE4547D-BE49-483E-9A4D-5EA0A94E2923
CuylerTech
NV
JLU Rubicon Bright White 3.6L 8 Speed
Did you make sure to spool the line under tension before using it to pull yourself/someone else out?
Robert
Dallas, Texas
Finance
Not as much tension as I should have.
Ribixcon
Dennis
NJ
Jeep Wrangler JL 2 door Rubicon
Hi all,
My understanding (and I am new to this winch) is that the red stuff is there to protect the synthetic cable from the heat that the drum might generate.
I assume the red stuff is still there, just has a rip in it. I would not worrie about it.
When you respool with correct tension on the this time - just make sure the red stuff is in between your winch drum and the black line.
NYC_Bobby
Bobby
NYC
2018 JL Rubicon, 2018 JL MOAB, 2016 Renegade Trailhawk
Hi all,
Give Warn a call, they are quick to answer and always very helpful. Take, send a few photos over.
NFRs2000NYC
NYC/NJ
2014 Jeep Wrangler Unlimited Rubicon
As mentioned, the red stuff is there to protect the line from the heat of the drum. Grab some cloth type tape (similar to hockey stick tape) secure it on there, and don't worry about it. (just dont use actual hockey tape, that crap has a tar like substance in it that is always tacky and sticky.)
