WARN JL Rubicon Winch Mount Plate and Zeon 10-S Install
Revs2ninegrand
Iowa
21 JLUR
Dusk update. The winch plate is in via 4 bolts and a bunch of zip ties per instructions. Spacer plate and winch are bolted to the winch plate. Works suspended due to dark. We resume tomorrow and start on the electrical.
did you finish?
Chile1
A
St. Louis, Missouri
2018 JLUR & 2016 BMW X5M
Biotech Sales Management
I'll be installing my Warn VR Evo 10s on the Warn winch mount plate this weekend and was wondering if it's true that the skid plate holes will need to be elongated. I've read on some posts that it's not necessary. Was wondering what was trick - keep everything lose and then tighten once the skid plate has been properly aligned or??
Overkill
Michael
Paris, IL
www.camaroheaven.org
2019 JLU Rubicon; 2018 JLU Sahara; 2002 TJ Sport; 2005 GMC 2500HD; 1969 Camaro (blue); 1969 Camaro (red); 1974 Chevrolet Cheyenne K20
Information Technology
I tried to install mine without elongation them, but after quite a while and almost crossthreading a couple bolts, I took it off and ground the back holes a little bigger to get it installed. The ones that have been able to, their holes might have just been within the right tolerances to fit. Mine weren't, unfortunately.
Chile1
A
St. Louis, Missouri
Some have suggested that you have to keep everything super lose and push on the skid plate to make the holes line up. Perhaps even inserting a large screw driver in the adjacent holes and prying until the bolt hole lines up with the welded nut. Seems like the skid plate may have a bit of spring flex to it where it curves!
I'll find out this weekend when i give this a whirl...
Tech Tim
Summit Sponsor (Level 3)
Tim
Poulsbo, WA
4x4 of all kinds
Part of the Northridge4x4 team
It's easiest if you elongate the holes a 1/4" or so.
Chile1
A
St. Louis, Missouri
i may just go that route as well. I installed my winch over the weekend but cannot get the f'ing skid plate to align. Do you have a picture on how you elongated the rear holes so it fits?
Tech Tim
Tim
Poulsbo, WA
4x4 of all kinds
Sorry, not one handy at the moment.
Slot it towards the rear of the vehicle, you only need to go 1/4", maybe 3/8" max.
Tech Tim
Tim
Poulsbo, WA
4x4 of all kinds
Dwayne Lane's Chrysler Jeep Dodge
