Warn 102370 Recovery Points for 18-19 Jeep Wrangler JLUR Steel Front Bumper
trailchaser
Javier
Haymarket, VA
2019 Moab
Thanks Tim. My JLUR parking sensors are front and rear, but I get what you’re saying, and the wiring isn’t the issue.
Regarding that end cap. Like yours, mine has the two built in nuts at the side for the two bolts that hold it on. But mine has a third nut at the front. I could either go out and buy a smaller bolt or just drill it out. Not a big deal.
Thanks for your comments re the integrity. I don’t have the experience to comment, but good to hear.
so anyway I decided to waste even more hard earned cash by ordering the Maximus-3 tow loops. I attach the install guide. The good news here is the detail is great ! Lol
Did you ever install them?
MacombRoger
Roger
SE Michigan
2018 JLUR Ocean Blue
Solution Architect
Yours look to be towards the middle, how come they aren't more to the sides like the others are showing?
Thanks!
I got the "d-ring mounts" not the "tow loops"
These: https://maximus-3.com/jl-bumper-accessories-/jl-d-ring-loops#/
Not these: https://maximus-3.com/jl-bumper-accessories-/jl-tow-loops#/
I suppose either works, looks to be the same basic size. The tow loops attach to the outside frame rails, I bet. While the D-Ring Loops mount to the bottom of their winch plate. So if you you don't have their winch plate, you can't have the loops I have. The tow loops look like a good alternative too.
trailchaser
Javier
Haymarket, VA
2019 Moab
probably a stupid question, but why do you need a winch plate?
MacombRoger
Roger
SE Michigan
Solution Architect
You need a winch plate to hold a winch. Although you can order the steel bumper group from Jeep, and it has a top & front plate you remove to access a winch opening, it still is not "winch ready" without a plate to support it. The plate basically ties the the two rails together and is a thick plate to bolt the winch to. https://maximus-3.com/home/jl-winch-mount-kit
tlindell
Tim
Newport Beach
2019 Jeep Wrangler Moab
How difficult was the cutting for the Maximus D-ring loops? I am looking to get the winch plate and am interested in the d-ring loops. Would you be able to share the installation instructions? I am a novice when it comes cutting steel but am handy enough (I think!) to figure it out. Thanks in advance!
MacombRoger
Roger
SE Michigan
Solution Architect
I can try to find the install instructions. But I just got a cheap harbor freight air-powered cut off tool and a couple blades? (abrasive wheels). It didn't quite cut like butter, but it wasn't difficult. Sparks will fly. It was sort of fun. :) You need to cut two u-channels out. I used a step drill bit to make the bottom of the "U", all around I made it slightly larger than the instructions said. Think it would have just as quick to just use the cut-off wheel and square off the "U".
JJsJL
NE
2022 JLUR ER, 2008 JKU Sahara, 2023 Yukon XL,
Tackled the Warn recovery point and Warn winch plate this week. There is a another thread regarding installing Warn recovery point too if your interested. Just search for it. Installing recovery point itself wasn’t bad at all. Cutting bumper just requires patience. I ended up using sawzall, jig saw and 4” angle grinder. All had their part.
Jeep Wrangler JL Warn 102370 Recovery Points for 18-19 Jeep Wrangler JLUR Steel Front Bumper 097B27FC-A719-4215-AE2B-0D1BACB27A89
Jeep Wrangler JL Warn 102370 Recovery Points for 18-19 Jeep Wrangler JLUR Steel Front Bumper 98D42F1E-62D3-46FF-B93A-5FC590F8268A
Jeep Wrangler JL Warn 102370 Recovery Points for 18-19 Jeep Wrangler JLUR Steel Front Bumper A6C44C01-C845-4DCB-B7F8-AA99453D54D9
Jeep Wrangler JL Warn 102370 Recovery Points for 18-19 Jeep Wrangler JLUR Steel Front Bumper FCC51F45-8D67-4CC6-B8D1-19AD096E3438
Jeep Wrangler JL Warn 102370 Recovery Points for 18-19 Jeep Wrangler JLUR Steel Front Bumper 7C281F4A-405F-45EF-B236-CC9AEC2C3690
Jeep Wrangler JL Warn 102370 Recovery Points for 18-19 Jeep Wrangler JLUR Steel Front Bumper 557EF57F-89E4-42E3-AD81-627790EB099C
Jeep Wrangler JL Warn 102370 Recovery Points for 18-19 Jeep Wrangler JLUR Steel Front Bumper 2BC2C8CB-50B1-4D59-B137-6228A59BBA35
gm920
Gary
San Diego County Mountains
2019 Jeep Wrangler JLUR Billet Silver
Aircraft Maintenance Technician (Retired)
Really nice job on the bumper cuts! Looks great, did you also reinstall the factory skid plate?
JJsJL
NE
Thanks!! Skid plate will go on. Small notches are needed in the skid and the two back holes need elongated due to the winch plate and that’s on the agenda for this weekend. So eventually. Yes.
gm920
Gary
Thank you, would love to see some close up pictures of the cuts to the skid, when you get it installed. I am using the Rock Jock (Currie) tow plate in place of the skid, trying to figure out if these recovery points will work for me.
JJsJL
NE
Ok will do.
JJsJL
NE
Updated with skid plate trimmed and installed. Turned out really nice! Had I used a little better matching paint to OEM that would be the icing on the cake!!
Jeep Wrangler JL Warn 102370 Recovery Points for 18-19 Jeep Wrangler JLUR Steel Front Bumper 45403D65-469F-4705-9EB6-75E4E534A9EB
Jeep Wrangler JL Warn 102370 Recovery Points for 18-19 Jeep Wrangler JLUR Steel Front Bumper F09D8888-4C50-4924-8199-2553F90A9212
Jeep Wrangler JL Warn 102370 Recovery Points for 18-19 Jeep Wrangler JLUR Steel Front Bumper 203E2054-14BE-431A-B044-C39830724DE1
gm920
Gary
Thanks for the pictures, very nice job. Look like they belong there. Did that notch take out on of the skid mounting bolts or were there only 5 across the front?
JJsJL
NE
You know it turned out I didn’t need to notch the bottom 2. It was tight but I got all 7 to thread fine. 5 across the bumper and the two lower screws.
JJsJL
NE
There were only 5 across the bumper. So none were taken out.
