Wanting to install an underseat sub I have leftover from my last vehicle, is this all I need
01tj
jason
Fairmont WV
Previous 2001 Wrangler, Kia Optima, possibly 2018 Wrangler unlimited
  • Thread starter
  • Thread Starter
  • #2
Here are the specs from the sub
LSguy
Ohio
2021 Willys
Personally I would run like an LC2i pro or similar. It's going to run you about $120 vs that $30 kicker adapter, but it'll give you a clean input for your sub and clear up the factory bass roll off.
01tj
jason
Fairmont WV
  • Thread starter
  • Thread Starter
  • #4
Would that be more difficult to install?
LSguy
Ohio
2021 Willys
Slightly, just because you'll need a power and ground. But its just 18 gauge wire, so you can basically tap into any power in the vehicle. Not bad at all. See the problem is, doing it the way you want it'll sound decent at low volume, but factory stereos as you turn the volume up the bass cuts out to preserve your factory speakers. The LC2i pro gives you back full bass at higher volumes.
TopLift Pros
