Wall-mounted door storage?
MIke Honcho
Canton, GA
2019 Sahara 2.0T
The way my current garage is set up it looks like I'll need a wall-mounted rack to store the 4 doors when I remove them. Good ones? Bad ones to avoid? (Pics of your storage would be helpful.) TIA
JWAustinVTX
Jason
2019 Sahara Unlimited
ARC works well for me. Makes swapping out trail doors easy
https://arcoffroad.com/
MrMischief
JL Rubicon
I’m using the arc door hangers as well. There may be a more elegant solution but for me the price was right (I only need two) and they seem to be a good product. Has worked well so far. I’d you go with those when you hang the door you put the metal piece into where the window would be. I see many photos of the doors resting in sort of that U shape. Apparently that can cause problems long term.
