MPTee
- Mark
- May 26, 2022
- Pacific North Wet
- Jeep - "nuff said
I just finished a solo run on the Washington BDR - 4 days on the trail, 697 miles (with a few wrong turns, re-routes, and explorations), great views, and very worth doing. I was running a block stock 2022 Rubicon diesel unlimited. I used the lockers a few times, but I think a stock Sport or Sahara could do it if you had another rig with you for insurance. Or a winch.
I didn't have any clearance issues, straddling any ruts that were too big to run.
Section 1 and 2 were flat gravel roads with lots of camping areas - no problem running these at all.
Section 3 had a few spots that would be worth having a friend along. One short hill climb of 18 degrees up 6" rip rap rocks was no problem with my rear locker engaged. Another spot with a 23 degree slant was fun but no real challenge for the rig.
Section 4 traveled through miles of burned forest - the regeneration that has already begun was incredible. A few washouts on the trail (along the edge of a cliff) made me pucker and use 4 Low and both lockers for the first time. The worst one was a 24 degree climb with a 13 degree twist (toward the cliff) that I would definitely want a spotter, extra rig, or a little help on next time. (I bought my nose camera for these things, but the breakover was so severe that it only showed where I hoped to end up - not the entire trail!). There were other tire tracks going through so I knew it was doable.
Sections 5 and 6 had the best views. Easy trails but highly recommended.
I used the BDR map and GAIA for navigation. Mostly worked, with a bit of guess work. Others on the trail recommended On-X.
I was in 4 Hi for 97% of the 697 mile trail and got an actual 20.9 mpg in the diesel. On the 350 mile trip home (over 4 mountain passes and several traffic passes) I got an actual 28.8 mpg. Incredible.
Highly recommend doing the trail or any portion of it. See our state, get some dirt time, test your vehicle, and have a blast. Not as much wildlife as I've seen in the past, but I did see lots of deer and elk, a bobcat, and the tail of what I believe was a cougar. And lots of birds. Going to sleep to the sound of bugling elk and howling coyotes was nice. I doubt that there was any place where I couldn't find a camping spot within 5 miles - guerilla, dispersed, or campground, and there were plenty of hotels along the route. Do it.
