FreedomFur
- Elliot
- Oct 26, 2021
- Concord, NH
- 2021 JLU Willys
i wired up the Voswitch Jl200 last week and finally wired my GRMS radio into it. All connections look solid between the Voswitch and battery. However, as soon as I turn on any aux switch on the panel on, I hear a clicking sound. Thought this was odd, so I then turned on the MXT400 I have wired to it and saw that that power to the radio was fluctuating rapidly, essentially turning the radio on and off very quickly like a flicker.
I have the Voswitch fuse box P power connected directly to the battery, with the P switch relay spliced into fuse 52 in the Jeeps fuse box and the N ground run straight to the battery per install instructions. I am also running the Voswitch fuse box switch #2 in the position that only gives the switch panel power when the vehicle is on. However, I did confirm the same issue persists when flipped the switch so that the switch panel pulls power straight from the battery.
Anyone run into an issue like this where their extra aux switch system isnt getting constant power?
