VoSwitch JL200 install/ reverse lights
FireCap84
Kokomo, In
2021 JLU Sport Altitude
I added the Rough Country rear bumper with built in tire carrier. I didn’t care for the coating so I sanded it down and re coated it. Since I’d sanded it down I’d added some flush mount LED pods to the rear bumper. I wanted to be able to have them trigger when going in reverse as well as manually turn them on so this is what I did.
I tapped into the reverse wire on the drivers side tail harness. I soldered in a diode that only allows power to travel one way to prevent back feeding the bcm when manually turning them on ( may not have been required but I felt better doing it ) this goes to trigger the relay to turn on.
Jeep Wrangler JL VoSwitch JL200 install/ reverse lights 2344D1C9-E95F-4A93-87A3-A99B05162D7F
I then tapped into the rear 12v cargo outlet to power the relay that 12v outlet is on its own 20a circuit I tucked the relay inside the tail light area out of the way.
Jeep Wrangler JL VoSwitch JL200 install/ reverse lights 881D5A48-10C1-49F3-9B8C-5F810C6A4836
the second wire ( to manually power the lights) comes from the voswitch box under the hood and is in loom under the Jeep to the rear tail light area
Jeep Wrangler JL VoSwitch JL200 install/ reverse lights 9DEC1974-39FD-4158-832D-5E63B94008BB
This is a pretty sweet setup to not have to run a million wires through the firewall it’s nice neat and all contained 8 30 amp relay’ed circuits
While I didn’t need 8 it will allow adding whatever else down the road with minimal wiring
Jeep Wrangler JL VoSwitch JL200 install/ reverse lights DF135B89-6FED-4733-B112-B68AB17A415A
The switch bank is illuminated and allows to be hot all the time or only on acc ( simply flipping a toggle on the circuit board in box under hood) bonus it includes 2 1” ball mounts and one cell holder..
Jeep Wrangler JL VoSwitch JL200 install/ reverse lights 2C0A4C10-BC4A-4046-AA74-FFC2B6A59B69
