Nice. I get the same thing, but hadn't thought to pull on it. I had assumed I'd have to look into poly fill, and what not, but this might just solve the problem.I’ve noticed for a while the bass was vibrating or buzzing. I reached back and pulled on the speaker bar and it went away 100%. Anyone else? I wonder if I can wedge something to make it stop.
hey,I’ve noticed for a while the bass was vibrating or buzzing. I reached back and pulled on the speaker bar and it went away 100%. Anyone else? I wonder if I can wedge something to make it stop.
Have to try that thanks! It is very annoying. Does your radio also cut in and out sometimes? I think it's like the satellite antenna not picking up the satellite but it happens often and i'm in a clear area.hey,
so I had the exact same problem and was able to fix it by putting a little rubber between the plastic sound bar and the metal roll bar on top. the seam has some really basic double sided tap that seems to seperate with heat and vibration... i didnt have anything rubber so i took a glove from a first aid kit and shoved it in the gap:cwl:... see picture below.
I notice the rattle in the pedals too.When the music is cranked way up, I noticed a vibration in the gas and brake pedals. Anyone else notice this too? Feels similar to the way brakes feel when they need new pads and or need new brake pads.
Yes, my radio cuts out often and I'm in a clear area as well.Have to try that thanks! It is very annoying. Does your radio also cut in and out sometimes? I think it's like the satellite antenna not picking up the satellite but it happens often and i'm in a clear area.
I had the same issue I lowered the bass to 0 and checked the balance set it from center to one to two clicks to the front speakers if it makes any sense. That work for me some how the vibration went awayI’ve noticed for a while the bass was vibrating or buzzing. I reached back and pulled on the speaker bar and it went away 100%. Anyone else? I wonder if I can wedge something to make it stop.
This drove me absolutely nuts, but at just under 3K KM in, i'm finally getting used it. Sadly I don't think there's a fix for that one.When the music is cranked way up, I noticed a vibration in the gas and brake pedals. Anyone else notice this too? Feels similar to the way brakes feel when they need new pads and or need new brake pads.
Thanks Dane. I did this exact same thing (even using rubber gloves) and so far no more rattle! I put the rubber in a few areas along the soundbar.hey,
